Chopper styled hot rod trike
Last Post: DeathBySnuSnu
70s Style Britt Choppa
New guy in FL
Looking for Talon lowers
Last Post: 2up2out200
Posted On: 05-22-2018
WCC coffin air cleaner
Old 02-26-2011, 01:37 PM
flysocal77's Avatar
How to prep fender bungs?
I am getting ready to install my rear fender. I have the standard bullet bungs as sold by wcc. What I would like to do (as opposed to just welding them on) is remove some material so it blends into the frame better. Should I just use a grinder or is there a better method? I think the rear frame rails are about 1" or so and would like to find a tool that cleanly removes the material from the bung so I fits the contour of the frame.
Old 02-26-2011, 01:44 PM
not sure on a west coast chop, but maybe drill into the frame , same size as the bung and slide it in and weld thats what i do
Old 02-26-2011, 02:47 PM
406_Customs's Avatar
Fly, I ran across this thread some time ago, I hope this helps.
rear fender line up - tips needed
Old 02-26-2011, 03:32 PM
flysocal77's Avatar
Perfect thank you
Old 02-26-2011, 04:06 PM
PharmD2B30's Avatar
Bike Year, Make, Engine: 2007, WCC CFL 250, 113" S&S
I drilled holes in my frame the size of the bung so the bungs wouldnt be seen sitting on top of the frame. The only bung I have showing is the one that I made with a curve on it to where it goes over the chain to allow for plenty of room for possible chain flap!!
Old 02-26-2011, 04:32 PM
Ras666's Avatar
Bike Year, Make, Engine: FXDX, CFL
are you trying to cope the bungs to contour the frame rail when welded? a belt sander works great as long as you dont remove your finger tips !
Old 02-26-2011, 04:53 PM
flysocal77's Avatar
exactly. I don't have a belt sander so I will monkey around with my grinder
Old 02-26-2011, 06:13 PM
dont forget about using a file.
Old 02-26-2011, 06:58 PM
you can use a 1" drum sander on a drill press.
Old 02-26-2011, 07:52 PM
Bike Year, Make, Engine: ~cfl~ ss113/brute5/jims6/weld5-2
-good idea too...never thought like that
-now that i am all welded up...lol lol lol
-routine day
-Don't Ban Me Bro !!!
Old 02-26-2011, 07:54 PM
tat2dale's Avatar
Bike Year, Make, Engine: 2012 CFL , 2001 FXDXT
Made my own bungs and coped them using a end mill on the milling machine.
[IMG][/IMG]
[IMG][/IMG]
HEAVY METAL SAVED MY LIFE
Old 02-26-2011, 08:15 PM
Smile
-dude; how long are those ?, and how much for 4 ?
-buddy oh pal of mine
Old 02-26-2011, 09:53 PM
flysocal77's Avatar
I'll take 5 if your sellin em.
Old 02-27-2011, 06:07 PM
tat2dale's Avatar
They are 1.750 end to end. I made them longer than needed so that I can face them to the length that I need before they are welded to the frame.
Its not worth my time to sell them unless I made 100's of them.
Old 02-28-2011, 10:25 AM
Bike Year, Make, Engine: 2006 CFL
I have a CFL 4 up that I had to mount 3 bungs for the rear fender to fit.
I would highly suggest to just get a round hand file and get the bungs to fit by hand. It didnt take me that long to get them basically to fit where I wanted to. I would say about 45 minutes for each one.
It is far easier to get the material removed (or coped) than basically any other way, unless you have your own mill.
the bung on the upper left of the frame is also challenging because its mounted on the frame here the frame tube curves inwards, so that has to be done by hand.
Basically, get it where you want, then spot weld it and double check everything!
I have my fender sitting about a 1/4" off my wheel and it looks TITS !
BTW, I have only 3 bungs holding the fender on, but I am never going to have a passenger sitting on the fender, so it is plenty strong enough.
