Buell XB12 Chopper
Last Post: FRANKTHECRANK
Wiring Issues, or Not?
Last Post: EdCase
Educate me on my bike
Posted On: 06-07-2018
Last Post: IHCKoy
Old 10-28-2010, 11:13 PM
Bike Year, Make, Engine: WCC
Starter & battery for S&S 113 ci
Hi there,
Just bought a S&S 113 CI engine with no compression releases.
What is the best starter and battery (that fit in the cfl tray) to go with the 113?
It's replacing an original Evo engine with original starter.
Thanks.
Old 10-28-2010, 11:18 PM
Bike Year, Make, Engine: N/A
WCC uses Yuasa YTX20BS batteries. As far as starter motors, the names I see get tossed around on here the most are either Spyke (1.4kW or 1.8kW), or All Balls.
Old 10-29-2010, 03:28 AM
Micahanjello's Avatar
On mine I run a 1.4 kw with a stock HD VRod battery but ya gotta keep it on a tender when not in use.
Old 10-31-2010, 11:23 AM
utwoodward's Avatar
Bike Year, Make, Engine: WCC Dragon/WCC CFL 250
Yuasa YTX20BS and All Balls 1.4 kW on my S&S 113 is PERFECT. Started right up the first time and can go weeks without charging. PLEASE trust me. My last 2 chops had a million starter issues. Just put your order in today and sleep well tonight.
There's No Life Like
Old 10-31-2010, 12:17 PM
Shaft01's Avatar
Bike Year, Make, Engine: 99 Custom 113ci S&S
Using the same battery as others have named here..... 310 CCA Yuasa with a Terry 1.8kw starter and no releases.....no problems.
Shaft
Keeping the rubber side down!
My ultimate goal in life is to be as good a person as my dog thinks I am...
Old 10-31-2010, 08:49 PM
So S&S offers heads with and without compression releases? I thought they used the electric solenoid operated compression releases located in the "hole" at the center of the rocker cover for all their larger engines. That's interesting.
Old 10-31-2010, 08:58 PM
PharmD2B30's Avatar
Bike Year, Make, Engine: 2007, WCC CFL 250, 113" S&S
Used a Braille with a Spyke 1.4kw starter on my S&S 113"....... Braille has all sizes of batteries to fit your application........ I think I went with the Braille B2015 without looking at my bike...... Makes 2-3 spins of the starter and cranks right up!!!
