10-06-2020, 05:10 PM
CA
Bike Year, Make, Engine: 2006 CFL 100ci twin cam
Parts!!!
More parts came in!
10-07-2020, 06:25 PM
CA
Finished machining my rear hub spacer.
Made a custom axle spacer to hide the right side of the hub from not being used since I'm running a sprotor.
Gona be bitchin once I polish it.
10-08-2020, 06:42 PM
CA
Axle Spacers
Finished the axle spacer setup. Wheels finally set where its supposed to.
10-10-2020, 12:00 PM
CA
3rd times a charm...
First sproket I ordered was a 23T .500 offset...
Was 1/4 out to far...
2nd one i ordered was a .250 offset... turns out I got one that wasn't thick enough... for a new model trans...
The 3rd one and final one was a .250 offset .76in thick for a chain drive conversion sprocket.... which turned out to be the perfect one... so now my chain alignment is nice n straight...
Also kinda got the idea of where my seats gona sit...
Still waiting on the correct back tire from back order before I can mount the the rear fender... which in turn I can then mount the seat...
10-13-2020, 06:38 PM
CA
Coming together
Threw the jugs and heads on so I could mock up the exhaust and weld the bung in on that. Put the bars and controls on for shits n gigs. And sat the motor mount on to see what it will look like. Still waiting on my correct back tire... still on back order... wish it was here so I could have everything else welded in...
10-21-2020, 06:39 PM
CA
Headlight mounted
Mounted the headlight... and the legs n forks... n front wheel. Tin just sitting on tire for now. New back tire should be here tomorrow then I can finally mount the rear tin and seat...
10-22-2020, 08:41 AM
TX
super cool - what lift is that?
10-22-2020, 11:34 AM
CA
APlus Lift its a 1500 pound rated one... got it from there website it was like 900$ and extents up to 9feet long
10-23-2020, 06:23 AM
CA
Tire finally came in
My correct tire finally showed up... looks like it's about almost an inch of a different from a 55 series to a 50 series... I'll post pics once I get it back from the tire shop. But here's a lil side view... can't wait to get it on the ground n see her stance
10-23-2020, 08:03 AM
TX
On first mock-up build I positioned my back fender same way as you.
I was thinking of a touring bike or something.
Later I changed it so it ended almost vertical - looks much better.
10-23-2020, 02:27 PM
CA
Id rather have the shorter fender also but the wife wouldn't let me build it unless she could ride with me sooo... full fender it is lol
10-25-2020, 03:02 PM
CA
Tires finally mounted
Got the correct tire mounted. Now I have plenty of clearance for the fender and the struts... might try n mount it later tonight after football... if not then my next days off
10-29-2020, 05:26 PM
CA
More fab work
Made new inner supports for the rear fender. Mounted the chain. Mounted the spider web struts. And tack welded em in. Just got mount the last 3 bungs for it. Next is battery tray n seat.
11-05-2020, 05:56 PM
CA
Putting in work
Got the inner supports welded into the rear fender. Got the bungs mounted to the fender. Got the spider web bungs spot welded in. Got the seat tabs spot welded in. Got the gas tank mounts spot welded in. Cut the fender to make space for the battery... still gona finish it up. Oh n spot welded the battery tray in too.
11-05-2020, 06:04 PM
CA
More parts
Got my 14in shift linkage today... and my 5hole points cover today!
Modified my motor mount to clear the fuel bung... still gota Modify the stainless loom holder its off 1/4in... musta been Modified for a sportster before I got it.
