Club Chopper Forums
-   West Coast Chopper Builds (http://www.clubchopper.com/forums/west-coast-chopper-builds/)
-   -   What size of wheels and tires for a CFL (http://www.clubchopper.com/forums/west-coast-chopper-builds/119602-what-size-wheels-tires-cfl.html)
nikkoweb 04-09-2017 09:43 AM
Hi everybody
I started to build a cfl 4 up with a springer front end ..but I need some help for... lot of things I guess ..starting with the wheels and tires.
I want a 200 tire but it s the only thing a know.
And nothing about diameter high thickness
But I want the tire very close to the fender
Does anybody can advise me on size, brand, models, any kind of detail?
Here after links to a chopper very close to what I planned.
Have a very good day and thanks for your help
Niko
Knucklehead CFL built by West Coast Choppers - WCC of U.S.A.
CFL DEAF FUCKER 4UP built by Garage Built Bikes of U.S.A.
DIABOLUS 04-09-2017 11:36 AM
The factory bikes used these tire sizes on most CFLs with 200mm frames:
Metzeler ME880 Marathon front tire: 80/90-21 on a 21x2.15 wheel
Metzeler ME880 Marathon rear tire: 200/50R18 on a 18x5.5 wheel
You can also use a 90/90-21 or MH90-21 up front, which both offer a little better traction versus the 80/90-21.
TWOWHLSIRVIVR 04-10-2017 06:14 AM
If you run a zero degree flex sportbike Metzeler rear 18" x 200 tire you can mount your fender very close to it. The side walls have very little flex if any noticeable movement which allow it to not rub on the fender.
pushrod243 04-10-2017 09:21 PM
For the rear Id recommend the Metzeler ME888 200/50 x 18. They are a zero growth tire so you can put the fender close to it without worrying. In the front you can 80/90. 90/90 or 120/70 x 21. Metzeler makes all 3 sizes.....
18 x 5.5 rear wheel
21 x 2.15 wheel for up to 90/90
21 x 3.5 for 120/90
nikkoweb 04-13-2017 10:40 PM
Very thank you guys !
nikkoweb 04-13-2017 10:46 PM
Great!
What do you recommend for a springer front end (Denver chopper ) like on my avatars?
Any idea of brand a models for a good price? 80 or 60 spokes
Have good day!
N.
nikkoweb 04-13-2017 10:47 PM
...i want to put a break on the front end.. exactly the same as the picture
DIABOLUS 04-13-2017 11:47 PM
I'm pretty sure that's a Freddy Hernandez springer. Couldn't tell you the length, every builder seems to measure their springers differently. But the frame looks like a 4 up.
John Spartan 01-06-2020 05:29 PM
Follow up question on the 250mm CFLs. Can someone advise what size rear tire was used?
pushrod243 01-07-2020 12:15 PM
Most likely Avon. Metzeler only offered a 240 and a 260. The Metzeler 260 was designed to go anywhere an Avon 250 was used it was a tad smaller than the Avon.
Custumlife 01-14-2020 01:11 AM
Boyd coddington front wheel on a cmc motorcycle
I bought a cmc bike that I believe was total custom job .....owner said guy he bought claimed he had 36k in it back years ago itís a 1997.......I no nothing about bike. Was polishing wheels and hidden behind the brake rotor itís stamped Boyd coddington.......I canít find anything on it.......if this is a one off custom that is really rare or a ton of them which Iím guessing not being google search brings nothing up
Any help would be great on how rare and value.....thanks
Spade115 01-15-2020 12:53 PM
any pics, specifics other than the brake rotor? Close up pics will help.
