Club Chopper Forums
-   West Coast Chopper Builds (http://www.clubchopper.com/forums/west-coast-chopper-builds/)
-   -   Hellion CFL Build. (http://www.clubchopper.com/forums/west-coast-chopper-builds/103960-hellion-cfl-build.html)
DIABOLUS 08-30-2013 12:18 PM
Retiring my old account HellionsMC. Time for a new build thread. My build is far enough along it's all but locked in. Expect lots of pics.
08.23.10 - Tank mount kit.
08.30.10 - Brembo controls.
09.10.10 - Knurled grip and footpeg set.
09.20.10 - Golan petcock.
09.21.10 - Ignition switch.
http://i894.photobucket.com/albums/a...psd42b81d7.jpg
10.01.10 - Throttle housing, cruise control knob.
10.08.10 - K&N black oil filter.
http://i894.photobucket.com/albums/a...ps6c8bf7a6.jpg
10.11.10 - WCC Coffin air cleaner.
10.18.10 - WCC dogbone.
http://i894.photobucket.com/albums/a...ps9e9c6d52.jpg
More to come.
Shay ski 09-01-2013 05:24 PM
What cfl frame are you going with? What specs.?
DIABOLUS 09-01-2013 11:12 PM
I'm 5'7" so at the time I was leaning toward a 2up frame. Hadn't purchased it yet though. As far as theme, I was thinking Barfly style: wide apes, Deuce forks, King Sportster tank, web struts. Nothing earth shattering. At this point, I wanted my bike to be exactly identical to a bike that would have come out of the LBC, down to the smallest details.
10.20.10 - OG Warbird light.
http://i894.photobucket.com/albums/a...psdb43b432.jpg
10.31.10 - WCC Diablo fender.
http://i894.photobucket.com/albums/a...ps73ac2855.jpg
11.12.10 - Hi/low beam toggle switch.
11.19.10 - Deuce axle kit.
11.26.10 - Wide apehangers.
http://i894.photobucket.com/albums/a...ps5c3831bb.jpg
12.01.10 - Bought some 2" WCC Maltese Cross risers that had been modified to fit on 1-1/4" bars. The price was very affordable and I figured it would work perfectly with my bars. When I got the risers I realized the boring-out job was very crude and looked terrible even after the bars were installed. I sold these pretty quickly, didn't even keep them long enough to take a picture.
12.06.10 - WCC Rigid 2-8 fender.
http://i894.photobucket.com/albums/a...psaa70b670.jpg
12.16.10 - Pike nuts.
http://i894.photobucket.com/albums/a...ps9dc4923f.jpg
Still just a small pile of parts at this point, but a lot of the key pieces to the Barfly look already obtained. More to come.
DIABOLUS 09-02-2013 08:49 PM
12.20.10 - Skull Krommets. Saw these on Jeff Decker's bike and took a liking.
http://i894.photobucket.com/albums/a...psd07fcd64.jpg
12.20.10 - Knurled passenger pegs.
http://i894.photobucket.com/albums/a...ps7502ceea.jpg
12.23.10 - Finally scored a 2" up frame. Had been searching on ebay for months and all I could find was 4" up frames.
http://i894.photobucket.com/albums/a...psd2f0a2cd.jpg
12.30.10 - WCC choke knob.
01.01.11 - End of the year proved to be a very expensive month for me. Wasn't planning on making any major purchases for a while after locating my frame, then a set of shop risers show up...
http://i894.photobucket.com/albums/a...ps85062b86.jpg
CloudDiver 09-04-2013 11:49 AM
Get her up on the lift and get cracking.... Hope to see a great build that you will really dig. Let me know if you need anything. I came up with a few tricks and special tools I used to get the rear fender mounted and drive line straight, which is the first and most time consuming part of your build process.
DIABOLUS 09-04-2013 02:41 PM
Thanks, yeah the rear wheel has been a nightmare part of this build and is still not completely resolved. This being my first build I made a lot of mistakes and wasted a lot of money unnecessarily. I'll be documenting it all in here, hopefully others can learn from my mistakes.
DIABOLUS 09-04-2013 05:16 PM
Parts collection so far, four months in:
http://i894.photobucket.com/albums/a...psaa5671b8.jpg
http://i894.photobucket.com/albums/a...ps6ff8cc9e.jpg
http://i894.photobucket.com/albums/a...ps6710fb3f.jpg
1badHD 09-04-2013 05:49 PM
Hell yeah!! Sweet! Can't wait for this build to start!!
DIABOLUS 09-05-2013 01:03 PM
The fun part of any build short of firing it up and riding it - mocking shit up.
http://i894.photobucket.com/albums/a...psf2aea45e.jpg
http://i894.photobucket.com/albums/a...ps52f3135b.jpg
From a distance the wide apes look good, except for the fact that the ends of the bars are a hair over 1" in diameter. On the shop bikes the Cyclesmiths bars had a step down from 1-1/4" to 1". On my bars the diameter is gradually tapered. I contacted Cyclesmiths and they said they don't make the stepped bars anymore. I tried sanding the bars but there is a good amount of material that would need to be removed in order for the throttle to operate smoothly.
Worse still, my risers won't clamp squarely on the bars when spaced out properly. If I install them squarely on the stepped-down section, they are spaced 3-1/4" apart, 1/4" shy of the proper riser spacing.
http://i894.photobucket.com/albums/a...ps88912a5a.jpg
http://i894.photobucket.com/albums/a...ps2bc79f0e.jpg
CloudDiver 09-05-2013 01:23 PM
I don't think the wide apes are the way to go, JMO... So if you are having trouble with the diameter I'd suggest Chassis Design Co. Bars. I don't think you will be disappointed with them.
TWOWHLSIRVIVR 09-05-2013 03:54 PM
CycleSmiths bars are what the DD has on it. And most of the barflys that came after.
WCCrider 09-05-2013 07:00 PM
Will be watching this build while wearing a lobster bib to catch the drool.
Mark
DIABOLUS 09-05-2013 07:05 PM
Keep in mind Cloud that these purchases all happened nearly three years ago, I'm just reiterating the build process. And yeah like Devon said, the shop used Cyclesmiths bars so that's what I bought, to my disappointment.
After finding the bars fit like crap, I was still determined to run them and figured I would simply grind the bars enough to clear the risers.
CloudDiver 09-05-2013 11:51 PM
If you grind them you'll expose raw steel and rust will follow quickly... I think you'll dig the apes Chassis Design Co has (3 sizes), and it will save you a huge head-ache. They come in Chrome or raw steel, probably for way less than you might think.
TWOWHLSIRVIVR 09-06-2013 05:06 AM
End mill the outside of the risers to fit around the 1.25" bars. They'll fit fine. There isn't anything wrong with CycleSmith bars at all. Check out JROCKS 2up, no problem with those bars at all. I looked at all kinds of other bars and the bend radius on all that I looked at are not as tight as the CycleSmith bars.
