Troubleshooting a Baker OD6
Last Post: Stick
Last Post: jaybird74
Open Primary belt question
Last Post: loren
Last Post: bigtwin100
need custom oil tank
Last Post: peach64
Old 03-21-2009, 12:04 PM
Bike Year, Make, Engine: 1982 Low Rider 80" Shovel
jworm
Please disregard my last posting. I had my mind on my own wiring problems.
You don't NEED an equalizer, if you get a transistorized flasher.
The stock flashers need the higher current from the incandescent bulbs to flash.
If you don't use the EQ. which gives the flasher the current it needs, you will have to work your turn button in and out to make the light flash, otherwise they just stay on.
No harm, just no flash. Sorry about that last post.
P.S. If you don't have a factory service manual for YOUR bike, drop EVERYthing and go buy one. There's no tool made that's worth more.
Old 03-23-2009, 08:06 AM
flasher
its cool thanx i appreciate the insight my flasher came with the harness so if I hook them up then it will hav to b manually triggered to flas????? thats cool im just tryn to get the basic stuff down so i can fire it and ride it, ill worry about that after i make sure itstarts, runs and the wiring is correct. thanx again ths is my first build so if i ask a stupid question then just charge that to me being a rookie thanx again
Old 06-23-2011, 03:54 PM
BadHabit's Avatar
I was hoping someone could tell me on the harness is the Aux wire "constant" or only with key on?
- A Society that will trade a little liberty for a little order will loose both,and deserve neither - Thomas Jefferson
Old 08-01-2011, 04:12 PM
Bike Year, Make, Engine: Sucker Punch Sally's Swedish hardtail
Should be, with key on.
easy to check with an OHM meter
Old 08-02-2011, 07:47 PM
BadHabit's Avatar
Confirmed that it is with key on....Thanks
