Last Post: Oldsmobile5798
Fender grommets
Last Post: muddychops
Trikes first run
Posted On: 10-23-2021
Old 07-22-2021, 04:12 AM
Bike Year, Make, Engine: custom 250 pro street, 127ci black gem
Charging system issue
I have got a 2 pin stator and my rectifier has the same 2 pin plus an extra wire. I am assuming that wire should run directly to the positive side battery with a fuse right? The charging system kit I got has no directions and the wireing diagrams I found on the internet have more wires than what I have. Mainly a "trigger wire and separate ground wire. I have my rectifier mounted to the front monitor mount bolts with a steel bracket, that should be enough to ground it out right?
On top of that, is that 2 pin directional cause it fits both ways in the hole. This isn't the exact system but same looking thing. https://www.denniskirk.com/v-factor/...prd/209980.sku
It's on my ultima 127 250 pro street. Thanks for the assistance!
Old 07-22-2021, 08:56 AM
Originally Posted by ball75 View Post
i have got a 2 pin stator and my rectifier has the same 2 pin plus an extra wire. I am assuming that wire should run directly to the positive side battery with a fuse right? The charging system kit i got has no directions and the wireing diagrams i found on the internet have more wires than what i have. Mainly a "trigger wire and separate ground wire. I have my rectifier mounted to the front monitor mount bolts with a steel bracket, that should be enough to ground it out right?
it's on my ultima 127 250 pro street. Thanks for the assistance!
2 pin connector carries alternating current from the stator to the rectifier, where it gets converted to 12 v direct current.
1 long wire is positive, goes to the battery. And the other wire [ nonexistent]is the negative: the body of the rectifier has to be attached via 2 bolts with star washers to the frame/bracket to carry the current.
the positive wire juices the battery via main breaker to prevent cooking.
Also I don't like Harley schematics allowing rectifier to be permanently connected to the battery even with the main fuse. If the rectifier goes bad, it may drain the battery.
Instead, I attach the rectifier wire to the "BAT" post of the ignition key where the battery main wire meets it, allowing to charge[ and i's already protected by the main fuse]
Old 07-23-2021, 10:10 AM
I always have connected the positive feed from the rec/reg box to the main 30 amp breaker , then to the battery.
And yes make sure the rec/reg box is grounded.
Old 07-23-2021, 11:32 AM
I was right just wanted a little confirmation. Thanks for the help!!
