I'm Baaaaaaaack...
Last Post: axeychrome
Posted On: 10-23-2020
Teardrop Gas Tank Replacement
Last Post: R1_4Life
Posted On: 10-22-2020
Posted On: 10-21-2020
Old 08-17-2020, 05:25 PM
Send a message via Yahoo to rstarost
18-530 Coil Wire - Black and White
Having dual coils, does this one wire run to the positive of the front Coil? I have everything wired from the 18-530 but having a hell of time getting the starter switch on the handlebar controls to do anything. I don't know if its how the controls are wired (wire colors were different than instructions) or if it is some other connection down the line? Do you know if you have to have the Neutral Switch wire connected?
Old 08-17-2020, 05:32 PM
Whats an 18-530 ?
Nuetral switch is for indicator light only.
Old 08-17-2020, 05:37 PM
Originally Posted by JamesS View Post
Whats an 18-530 ?
Sorry ULTIMAŽ ELECTRONIC WIRING SYSTEM #18-530. one of its connections is a Coil + wire which shows it going to the coil? Not sure if it matters if its a single or double coil.
http://www.ultimaproducts.com/18-530.pdf
Old 08-17-2020, 07:46 PM
Need more info.
Ignition?
Coils are single secondary high voltage tower?
There is a wire missing off the diagram. The B/W wire should go to the positive primary connection. And come live when the key is turned on. For 2 coils ; connect to one and jump to the other.
The negative connection should go to the ignition.
Old 08-18-2020, 04:06 AM
Need more info.
Ignition?
Here is a diagram of how I have it wired right now
Old 08-18-2020, 02:57 PM
The 2 wire to the positives on the coils should get 12 v when the key is on.
Its a single fire ignition with single HV tower coils.
Check that first
If there is no power check the run/off switch on the hbar and see if power is getting there , then see if the switch is letting power through.
Look at the chart , there are few wires , remove all of the wires from you thinking , we are talking about one or two, easy to check.
Old 08-19-2020, 10:04 AM
Check that first
Got it. it was 12v to coil when key is on. Didnt have that wire. Started right up! Thanks for all the help
Old 08-19-2020, 10:31 AM
Glad to help.
Old 08-26-2020, 05:41 AM
axeychrome's Avatar
glad you got it. i loved building bikes. metal work, paint work, engine work, all of it...except the wiring. if the electrical worked at startup, great, if it didn't, F#CK!!!!!!!!!
took me one build to learn i needed to delete blinkers, horn, speedo. made life much easier.
Axe - record for fastest motorcycle ride across America
"No Limits - No Regrets" movie
http://www.ychrome.com/movie
