TP engineering 107
Last Post: vin1800
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 08-21-2016, 11:43 PM
slytat666's Avatar
Fuel sending unit help
I have a harley dyna sending unit. And I am using a koso universal all in one guage. How do I change the resistance of the sending unit to work properly with the guage. I want to use the set up I have, just need some help to use resistors
Old 08-22-2016, 08:42 PM
One of the easiest ways to do something like that is to take an ohms reading of the sending unit
and then just wire in a reostat of the same value in series with the sending unit..probably about 1k ohms...a reostat is just a potentiometer with two of the leads soldered together..Fill your tank up full and try to dial in the gauge..you may or may not have to add a resistor in parallel..
Old 08-22-2016, 09:58 PM
ecir45's Avatar
no work around, get the proper sending unit for the gauge.
113" El Bruto / 5 speed
