TP engineering 107
Last Post: vin1800
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 07-28-2015, 12:28 PM
slytat666's Avatar
Question Oil leak from primary side
So I found a small oil leak coming from the primary side of the engine. I have taken primary apart and found the issue with the engine binding in one spot, but I have a small oil drip from the splines where the shaft comes out, not from the oil seal. Is this an indication the seal needs to be replaced??
Old 07-28-2015, 10:02 PM
Bike Year, Make, Engine: 2012 Custom Rigid, 127CI Ultima
I hope this is not the same issue I am having. Is it an ultima 127? I would say, replace the seal and out high heat rtv around the splines and see if t still leaks.
Sua Sponte
De Oppresso Liber
My Store
Old 07-28-2015, 10:20 PM
slytat666's Avatar
It is a 110 revtech... I ordered a seal, so see if that fixes it... Just weird it's coming out of the splines and not the seal...
Old 08-02-2015, 09:00 PM
slytat666's Avatar
Figured out the problem
Old 08-03-2015, 01:12 AM
Could you let us know what the problem was so we can get an education? Hope you guys are running primary support..
Old 08-03-2015, 12:42 PM
slytat666's Avatar
Sure, so what it was is that the bike has been sitting for quite sometime and all the oil has gone into the case, no oil in oil bag, since there was no pressure on the crank shaft, from the pulley, oil was coming out the splines. The binding was due to the stator rotor hitting the wiring connection inside, had to replace the rotor, as it had a dent in it. Put primary back together and the engine rotates fine and no oil
Leak
Old 08-28-2015, 12:01 AM
slytat666's Avatar
Thank you for all the help, bike is running great
Old 08-28-2015, 08:53 AM
Originally Posted by slytat666 View Post
thank you for all the help, bike is running great
and what was leaking?
Old 08-28-2015, 11:53 PM
slytat666's Avatar
Oil was leaking from the primary side of the engine, as there want enough pressure drone the nut on the pulley, the engine was having a hard time turning over, thought it was engine, but found out it was the clutch hub rubbing in the primary backing plate. After it was all out back together, no leaks
