Its been a bit since i put down an update. I've got a lot of progress over the last couple months.
Here is the whole bike broke down into a pile of parts. Frame got painted black around this time. I decided to assemble it on the floor since it would be hard to get off the table as a whole bike.
I got the wheels and front end put back on the frame.
I started the wiring. I used scooters simple wiring harness. It was well labeled and the directions were clear. The difficult part is it was still a giant fucking pile of wires which was a little daunting to start. I mounted all the breakers, starter relay, ign switch and hi-low beam switch all on the
oil tank. That kept the wires hidding and mostly out of the weather.
Wires getting run around. I didn't run them through the frame because i want to get to them if i need to.
Brake Light works!
Wires were all run through wire sheathing to keep it clean looking. I soldered every connection and heat shrinked them to seal them as best i could.
Headlight works!
Ignition all wired up and put together
Wiring almost done.
