Go Back   Club Chopper Forums > CUSTOM BUILDERS/DISTRIBUTORS > Two-Bit Choppers
6 Solo Seat Cover Needed
Last Post: jortegaa3289
Posted On: 12-01-2021
Posted On: 11-29-2021
21" Doom Front wheel needed
Last Post: LorenzoHD
Posted On: 11-26-2021
Evil Bitch
Last Post: Choppa
Old 01-30-2006, 07:13 AM
buell help
Can anybody tell me if a 91 buell fuel injected has the same mounts a cv carb? Do you have to worry about any sensors.Or will it bolt right up??
Old 01-30-2006, 09:16 AM
mutantbuell's Avatar
Bike Year, Make, Engine: 2004 Redneck Mutant Buell
I'm a little confused, did you mean a 2001, not 1991? Buell didn't fuel inject bikes until 1999 on the X1 and S3 models. Either way though, all late model Buell engines are the same outwardly, and the EFI bikes can be converted over to a carb and standard ignition pretty easily.
Take a look a this donor bike article I wrote as it goes over donor selection and the technical differences between years and models.
Mutant Buell Donor Bike Article
Let me know if I can be any other help,
Justin @ Two-Bit Choppers
If the Price is Right Chop It!!
http://www.twobitchoppers.com
Old 01-30-2006, 11:58 AM
Sorry it is 1999 lighting fuel injected.Is it the same as mounting as cv carb.Or can I mount a velocity stack on a fuel injected 1999 or not?(any sensor problems)
Thanks for your help
Kevin
Old 01-30-2006, 03:56 PM
V-dude
They are the same bolt pattern as the carb but the factory airbox has a provision for an air temp sensor. you will have to relocate it some where near the air supply so its not to overly effected but the engine heat. Forcewinder uses a bigger filter that has a provision for the temp sensor to slip inside but its kinda bulky looking. I have been just relocating the sensor near the elbows base so it is seeing similiar air temps as the intake.
Old 01-30-2006, 05:31 PM
Thank you for helping me out.I do not know alot about buell injections. This is the answer i needed....This is a big help.
And again,Thanks for helping
Kevin
Old 01-30-2006, 05:42 PM
No problem
