Originally Posted by Activate
Hello another question about A Ultima Drag style Clutch hub.
Is it normal that there is a certain play (up and down) in the hub?
There is no play from left to right.
Thanks and greetings,
Erik.
Internal or external hub moving?
I would expect the internal hub sitting solid on the splines when the tightened by the nut. and there should not be perceivable bearing play for the outer hub.
