2001 Road King, again
Last Post: CIC2016
Turning trouble
Info on a New York motorcycle shop from the 80's
Last Post: Dogoargento
Identification Help
Last Post: mchesmo3
WCC CFL Build for sale
Last Post: jmurray72
Posted On: 06-10-2019
Old 03-06-2019, 06:11 AM
question about coils
2003 aih, legend.. looking to replace coil testing bad it is 2.89 ohm coil im having trouble finding a coil with 2.89 ohm can you use 3.00 ohm or 5 ohm ? dual fire coil.. it has a compufire elite 1 ignition.. thx
Old 03-06-2019, 09:27 AM
Probably..I wouldn't necessarily just go by an ohms test...Hook the coil to 12volts and then scratch to ground, ...that's all the module is doing anyway..... if it gives a nice hot spark then it is ok..One or two ohms one way or another
most times doesn't mean anything...
Old 03-06-2019, 02:12 PM
check your coils should have a number on it. my uncle bought a rigid, 80 evo 6 speed 2x5ohm coils 0.0 he blew an ignition.
definitely make sure you run the right coils.
Old 03-06-2019, 05:09 PM
Thanks for the replies
Found a 3 ohm
It's the same style as evo softail I had a while back
