bmc wiring diagram
Last Post: bluballin
Posted On: 07-04-2020
Identify Frame *Help
Last Post: Maustarman
Last Post: erlobulldog
Posted On: 07-02-2020
Posted On: 07-01-2020
Old 06-02-2011, 09:45 AM
stu22180's Avatar
Bike Year, Make, Engine: SMW LoBoy Kit, 2011, 100
Lo boy build "where to start" help
My lo boy kit came yesterday. I was happy to see it... Now what goes fisrt. Is there any manuals or book that can help a newbi?
I down note the following parts are backordered:
1- 16X3.5 40 Spoke Wheel
Bushing for Springer Brake
2- Testament Rotors
Weld On Exhaust Tabs
Exhaust
3" Open Belt Drive
Thanks for your Help
Old 06-02-2011, 07:37 PM
CruznLo's Avatar
Bike Year, Make, Engine: 2006 WCC CFL
I started with all the fabrication and welding first, trim and fit the tank mounts, drill and fit the rear fender, tack the seat spring mounts. Mount the motor and tranny, then position your exhaust, trim, fit , and tack your exhaust mount tabs. Decide where you want to put your Thunder Heart MHC, I fab'd a SS bracket and mounted it in between the tranny and rear fender. If you are going to hide you wiring, I drilled the seat post and backbone to run the harness up under the tank. I also drilled to run the wiring for the brake/license lights to the left side rear. I didn't bother with blinkers, not required in WA. The wiring from under the tank goes to the controls, I drilled my drag bars. The ignition wires will stop and connect from under the tank. Always measure twice, because you only drill or cut once and that is it, one less thing to have to deal with "corrections." Sooner or later you'll just have to "go for it" and start…Good Luck
Old 06-02-2011, 07:42 PM
CruznLo's Avatar
Oh, of course for the rear fender you will need to have your backordered rim, then mount your tire. Don't forget to set up your spacers, front & rear and center both tires. Position the rear tire, then drill, trim, and fit your rear fender...
Old 07-22-2011, 11:43 AM
stu22180's Avatar
Now I fell realy kick-it the kit build gear... Only the short the rear wheel.
