Last Post: pop 28
Last Post: chopperdiva
Last Post: Green
starting issue
Old 06-02-2012, 03:56 PM
Bike Year, Make, Engine: Bourget, S&S 113
Question HELP What Brand Forks do I have???????
I need new fork seals for my 99 BOurget Low Blow with inverted forks.... 45 MM The build sheet states "New Inverted Forks" I guess it was a short run cause ext ream choppers in PA have no idea and I cant get a response back from Bourget in AZ. Perhaps the divorce...lol. Anyway can anyone ID the brand or equiv. part. My photo gallery gives a decent look at them..... Any help is a great help thanks
Old 06-02-2012, 04:44 PM
magnum45pete's Avatar
get your seals out of your forks and take them to a bearing seal supliers and they will match them...
they will be a standard size and type available over the counter.
or measure them and look on ebay..............this will be a shit load cheaper than Bourget for the same seal............
Old 06-03-2012, 06:51 AM
joyridin''s Avatar
You need better pictures and a few close up ones of the top triple tree and maybe where the top and bottom sections meet. How it mounts to the wheel might help also.
Old 06-04-2012, 04:54 AM
Best way is what pete said it's not to hard to do you could also take the cups off the lower leg then you should be able to a seal number.
Old 06-04-2012, 04:55 AM
sorry i ment upper leg.
Old 06-04-2012, 05:24 PM
skylarbluepuppy's Avatar
Bike Year, Make, Engine: 06 pitbull
inverted fork seals are usually sport bike seals cbr or gsxr
Old 08-20-2012, 09:56 AM
ok found out the forks are made by mean street and they take stock hd seals....thanks
Old 08-29-2012, 08:45 PM
OK that didnt work... Note to self Mean Street Street Stalkers 63mm take a 45mm seal off of a CBR 900... A pain to figure3 out but man it was worth it my ride is sooo much better. Oh yea if u change them buy extra fluid each one takes over 26 oz.
Tags
bourget, forks, seals
