VTR1000 Chopper
Last Post: Trikeopath
tips for setting up two piece primary
Last Post: nsdq3
Sum Bich!!!
Last Post: 250CFL
Baileigh industrial May 2013 Metal Shaping Class Tour
Last Post: BAILEIGH INC
Old 05-22-2012, 02:50 PM
79 4 speed
i have a 79 flh after about 50 to 60 miles the tranny gets had to shift,after a while it gets better ,i thought mabey low fluid but that was'nt the case .any ideas would be apreciated
Old 05-22-2012, 06:29 PM
Welcome to CC! That problem could be caused by a number of things, I'd start simple and lube all of the shifter linkage, adjust the clutch pushrod and the cable, also adjust your primary chain. When you take the derby cover off to adjust the pushrod look into the bottom of the primary and make sure that there is only a 1/2" of oil(or so) in the primary, if it's allot more than that you might have a scavenge problem in the primary and you"ll need to check your feed and return hoses. The next step would be to take the plates out of the basket and check for excessive wear.
Old 05-23-2012, 02:56 PM
traynor's Avatar
Bike Year, Make, Engine: 100ci donnie smith xts
Sounds more like a clutch problem? Have you isolated the primary?
Old 05-23-2012, 10:57 PM
Thanks for the input ill give it a try, thought it was the tranny ,as when I pull in the clutch lever it disengages the engine and tranny u
