Last Post: Boogeyman
Sum Bich!!!
Last Post: Anthony pelillo
tips for setting up two piece primary
Last Post: Green Bean
Old 05-17-2012, 05:06 AM
joyridin''s Avatar
Balancing your wheels..
My bike has a bouncing effect when driving down the road. It did not do this when I first installed the new front tire. My first assumption is the tires are probably out of balance.
I see DennisKirk has a wheel balancer. Anybody have or use one of these? Are there cheaper versions that work just as good? What do you do for weights?
Old 05-17-2012, 05:30 AM
gypsy chopper's Avatar
There isn't really any difference between your axle and a wheel truing stand.
Remove your caliper, jack the bike up spin the wheel. If it's the rear....remove the drive belt or chain also.
Mark the bottom where it stops with a sharpie. Spin it again, mark it. This will show the heavy spot.
It should stop at a different place every time, if all your marks end up stopping at the bottom, put a weight directly above. Try various weights until it never stops at the same place.
Unless you are a shop or just want the stand for various reasons, you probobly don't need one to do a couple of tires a year. When you mount the tire put the paint mark on the tire at the valve stem hole in the rim....that should get it close as long as it's a quality tire and rim.
Wouldn't that vendor also sell weights?
Old 05-17-2012, 05:41 AM
magnum45pete's Avatar
unless it's on a shaft drive bike I wouldnt bother balancing the rear wheel....when you are running , the belt or chain being only on half the wheel at a time, will make balancing pointless on the rear wheel.most HONEST shops will tell you this and the others just want ya cash
the Front wheel is differant , and does need balancing ,as it is basicly freewheeling without a chain throwing the balancing out as the wheel turns.
Old 05-17-2012, 05:46 AM
I just use the dyna beads..no problems
Old 05-17-2012, 06:37 AM
Not too many listen to the turtle, but if you took two coffee cans, two chairs, set the axle on the cans that sit on the seats is a gap for the wheel to spin. There is your balancing stand. As stated, if you can make that wheel drop at the heavy spot, the weight should be heavy enough not to run the wheel back up to the lightest spot is at the top again.
The idea is to wrap thick solder wire around the [top] spokes, so when you let go of the wheel in any position; it stays were you put it. Even your hand can tell [ by the weights], it will stop easier as you grab the wheel to spin it or move it to any'o'clock position.
If they balance racing wheels front and rear; if a wheel spins this freely; if you don't think you can feel a vibration at over 200mph [these days] on a sport bike; if you wear depends or poise... Forgo the rear balancing act at 70mph or highway speeds? Oh Really? Have I got a veggie table garden for you!
Old 05-17-2012, 08:12 AM
bigtwin100's Avatar
I haven't balanced tires on my HD's or chop in 10 years. No problems
On my track bikes I do
Old 05-17-2012, 08:29 AM
as said,I always balance my fronts....not the rear less it's on a High-performance bike ..
Old 05-17-2012, 08:32 AM
bigtwin100's Avatar
to OP, if your tires bouncing around I would look at other things. Doubt the balance is the culprit
Old 05-17-2012, 06:02 PM
caschnd1's Avatar
On the front it absolutely can be the balance causing this. I see it all the time. About 1/2 the front tires I've put on my bike need to be balanced, the other half don't. I always ride the bike without balance to see. I've had some that would really get to hopping on the freeway. As soon as they are balanced it's no longer an issue. Balance the wheel and see how that works before you go any further. It's fast and easy. Always start with the simple stuff.
-Craig
Old 05-17-2012, 06:05 PM
bigtwin100's Avatar
Well then I must be extremely lucky to never have had a problem in 10 years of not balancing
Old 05-18-2012, 09:57 AM
joyridin''s Avatar
I'll jack the front up and give it a try. It is a billet wheel, so balancing isn't as easy as wire around a spoke.
It ran fine for a while. Maybe it has a flat spot from sitting all Winter.
Old 05-18-2012, 09:25 PM
purpleride's Avatar
Send a message via Yahoo to purpleride
ah never let a bike sit all winter lol
Old 05-18-2012, 10:13 PM
caschnd1's Avatar
Maybe lucky. Or maybe you buy a better quality tire then I do. I use the ancient Speedmaster 21" front tire from Avon. This design has been around since the 60's. I'm sure there are better tires, but the new tires look out of place on my old chopper. When I do get one that "hops", balancing them always solved the problem.
-Craig
