Last Post: Green
Last Post: chopperdiva
Last Post: Green
starting issue
Old 04-14-2012, 08:00 PM
Runnin on one cylinder
127ci Ultima, ultima single fire ignition'...
At very low rpm, just above idle it has been sputtering lately. At first I thought it was carb tuning issue ... so I just lived with it, but now i think it's ignition.
last time out I held it right at that rough spot at stop lights, etc. and I could pretty clearly here it going to one cylinder...and back...didnt sound like fuel issue to me. If I increase throttle at all it takes right off and sounds fine, runs good from there on.
So, it isnt much issue at all except in parking lots, etc. it can occasionally sound shitty. I am just worried itll get worse and eventually leave me stranded.
where shoudl I start?
I thought about messing with the carb (mikuni) but I know next to nothing about it and I really dont think thats it.
Old 04-14-2012, 09:17 PM
I assume its the rear cylinder as usual. If so change the rear plug up to the next cooler plug.
Old 04-15-2012, 01:01 PM
hey thanks redwings
common, ey?
Old 04-15-2012, 06:33 PM
Razorback's Avatar
If that don't do it look for manifold air leaks. First time I lost a cylinder with this new build it was a leak on the front cylinder. At idle she was missing bad once I was heading down the road with more throttle she wasn't bad. Last time I lost a cylinder just before I tore it down for paint it was coil related. I limped it home shut it down and that was it she would not fire on either. She did not run again until after paint and a new coil.
Old 04-15-2012, 06:47 PM
thanks razor
I went down from RN11YC4 to RN9YC and no change. Might try one more step.
Old 04-15-2012, 06:58 PM
Will copper core plugs run on electronic ignition? I thought they had to be resistor type. I run r12yc's but I don't run electronics.
Old 04-16-2012, 06:39 AM
Ricky-D's Avatar
Electronic ignitions have very specific needs regarding the components (plugs and wires) which, if ignored, will ultimately result in a lunched ignition module.
Seems to me, this could be the case with the ignition being discussed in this thread.
Old 04-16-2012, 01:25 PM
the RN11YC4 came in it from the builder, altho that dont mean a whole lot
except that he seems to get EVERYTHING from midwest, so it seems like it would be dialed
its got ultima plug wires, altho maybe there are many
Old 04-18-2012, 01:29 PM
single fire
would check for the air leak at head, maybe ring gasket or mount bolts loose.
copper plugs have been used for electronic ign. for long time. if it cranks good cold and hot i would put the plug at the bottom of the list. carb. bolts good and tight?
if the carb needs adjusting go for it. satisfaction is better even if it's a couple weeks after screwing it up than having someone else do it for you!
rem-h.
Old 04-18-2012, 03:42 PM
thanks
ok
yep it does
need to check
agree. started looking at the manual last night
thank you !!
Old 04-19-2012, 03:47 AM
Sounds like an air leak to me, start it up run it at the rpm that it faulters then spray some ether towards the intake's and carb, if it pick's up then you have a leak. mic carbs are easy to tune and set up, go to there site have a look very easy to understand. good luck mate.
Old 04-19-2012, 06:56 AM
thanks
looks like you have a seriously fast heritage!!
Old 04-19-2012, 12:08 PM
Watch where you spray; If the carb even gets a sniff of ether near the mouth of it, it will pick up RPM.
I like carb cleaner myself. Not as explosive or dangerous as ether.
Any spray that is combustible will pick up RPM if there is a leak.
Non combustible liquid will drop the RPM.
Old 04-20-2012, 06:16 PM
ewp1954's Avatar
Send a message via AIM to ewp1954
2000i dyna did the same,rear cylinder was not firing,replace dyna 2000i and it was fine,also dirt in the tank will cause it to misfire if it cant get enough gas
Old 04-22-2012, 05:39 PM
Ordering new 2000i now
