Hello!
Last Post: semiller1911
Last Post: Miamio96
Axe's 300 Gripper build project
Last Post: axeychrome
Sum Bich!!!
Zink's 4up CFL build
Old 04-09-2012, 11:32 PM
SKOOTERBUM's Avatar
Bike Year, Make, Engine: HOME BREW, REV TECH 100, 6 SPEED TRANS
torque cone question
to run, or not to run ??
that is my question ......
i have a set of torque cones for my bike. my bike has a stock from the factory
Rev-Tech 100ci engine, with the el-cheapo Big Growl pipes on it.
like these.....
http://www.parts123.com/parts123/yb....Z5Z5Z50000123a
should i run the cones ??
will they make a real difference on the performance ??
thanks again,
Ron
SKID ROWE
DONT SICK THE MRS'S ON ME
SHE IS SO SCARY
Old 04-10-2012, 04:11 AM
foggdog's Avatar
I use em in my sporty builds, but I dont think you should use em in a big inch motor. They rob to much top end. I would get a set of 2 1/4 baffles (they kinda look like a torque cone) and stick those in the end of the pipes.
Like these Baffle Rings for Exhaust | 4400470 | J&P Cycles
Old 04-10-2012, 06:09 AM
NickD's Avatar
I've got 2 1/4" Big Growls too. They look good but they are simply to big diameter wise. Tried all kinds of baffles, some I bought some I made myself. So far the best thing that's worked, as far as sound and bottom end power, is the latest thing I did. I slid 1 3/4" lightweight steel tubes into the pipes running full length and sealed (between pipes) with exhaust wrap on both ends. I also tried torque cones in the past and they didn't seem to make any difference.
Old 04-10-2012, 06:43 AM
bigtwin100's Avatar
They don't do anything. Just a gimmick
Old 04-10-2012, 11:30 AM
SKOOTERBUM's Avatar
thanks guys !!
torque cones are for paper weights, and make some baffles to downsize the ID of the pipe some.
sounds good, and i won't have to remove the pipes to do it !!
ron
SKID ROWE
SHE IS SO SCARY
Old 04-10-2012, 11:32 AM
bigtwin100's Avatar
You can file them away with single fire ignition.....ok let the bashing begin
Old 04-10-2012, 11:49 AM
SKOOTERBUM's Avatar
ohh shitttttttt, now i'm going to start having problems with my ignition ???????
LOL
SKID ROWE
SHE IS SO SCARY
Old 04-10-2012, 11:51 AM
bigtwin100's Avatar
ha! no you're good man
Old 04-11-2012, 05:24 AM
foggdog's Avatar
They work in the xl motors, my brothers xl will leave a big twin sittin until they hit
4th-5th gear then they walk away from him. They definitely improve low and mid range torque.
Old 04-12-2012, 06:45 PM
choppers_rule's Avatar
Bike Year, Make, Engine: 87 Rigid Sporty & 07 WCC project
I use it in my XL motor, improve the low end torque for sho because I'm running straight pipes.
Keep it low,rigid, and loud!
Old 04-12-2012, 07:10 PM
They dont work and in some cases actually hurt torque and hp.A good tuned exhaust will make a huge improvement, torque cones won't...
Torque cones go in the wrong end of the pipe to do any good.
Old 04-12-2012, 08:22 PM
bigtwin100's Avatar
exactly.....
Old 04-13-2012, 06:02 AM
foggdog's Avatar
Your wrong, they even say not to use in big inch motors.
Old 04-13-2012, 06:06 AM
foggdog's Avatar
1 3/4 drags on my brothers, and it is quick . Gonna find out soon on another xl build with Exotic's xl fuelie pipes. Gettin wired, then she's done.
Old 04-13-2012, 08:19 AM
It is all about air flow.
If the pipe was equal diameter, it says, for every pressure, there is equal pressure (back up the pipe); Not filling the larger pipe diameter first. It stalled right there on the reversion filling that void.
It took time to fill that pipe. The overlap suffers. What should have been pushed back into the cylinder [with an equal diameter pipe] on that part of the air dynamics, the unspent was somewhere in the larger diameter, if not right at the edge of the smaller diameter area. I'm taking a guess?
I know a sonic wave has to start someplace. I measured about 8 to 9" into the exhaust? I can see a hot spot at the pipe there for both pipes read in similar inches. My guess is it pops/backfires right there. You hear that cannon fire out of that 8" barrel or the end of the exhaust's tip.
That's my take on the change in diameters. That they do work to mess up the torque [in a good way]. Bottom end rules the stoplight = You dart away ~ No metal around you. If they sustain the speed limit, they should never come close to your jump. If all things were ideal on the road.
