Last Post: manser
Last Post: 250CFL
Last Post: Ken448
Does anyone have any info on Prowire management system?
Old 04-06-2012, 11:56 AM
Bike Year, Make, Engine: 94,harley,80evo
Speedo wiring help???
Where does the "Speed Signal Output" wire go to on a 1996 and newer Softail, or on a 2003 newer Softail ?
I'm trying to put a newer Harley electronic speedo in my 94' Heritage.
Thx
Old 07-15-2012, 06:26 AM
99 - 03 speed signal output wire (white) goes to pin 9 on 12 pin. Also if your putting a older speedo on a 04 or newer bike its not going to work 100 percent because the older bike didnt have ecm,cruise and all that . turn sig,self canc and speed should work fine though. Thats about all the old speedo had.
Old 07-15-2012, 06:42 AM
99-03 serial 67027-99 12 pin are as follows
1-o/w to front fender light,l turn sig switch,rear brake switch,rear fender tip
2-grey or w/g to trip meter
3-6 not used
7-black to ignition module and ground
8-red to speed sensor 12+
9-white to speed sensor output
10-black to speed sensor gnd
11-grey trip switch
12- w/g to turn signal canceller
hope this helps and if you have the pin positions for a 04 and later please send them to me currently looking for them now.
