I'm Baaaaaaaack...
Last Post: axeychrome
Posted On: 10-23-2020
Teardrop Gas Tank Replacement
Last Post: R1_4Life
Posted On: 10-22-2020
Posted On: 10-21-2020
Old 10-31-2011, 06:55 AM
Wiring Trouble Shooting
So first the rear turn signals quit.
Then the tail light too.
I have the tore down anyway for a couple of other things that have been entertaining you all on here, (clutch throwout bearing, replace shit chain with actual chain)...so I thought I'd try to figure out the wiring too.
I start monkeying with wires, tracing them to figure out whats what - walk around the back and bump the ratchet i had left in the axle nut and bang...tail light works. So, I am sitting there moving the ratchet back and forth turning the light on and off (WTF seems like no connection at all between the two) scratching my head.
I guess maybe the light is shorting out through the bracket to the axle? Or a grounding issue.
No idea on the turn signals yet...
Old 10-31-2011, 07:05 AM
Ricky-D's Avatar
Seems like you have lost a ground.
Old 10-31-2011, 05:23 PM
I agree try running a ground wire to the light it may not be getting a good ground throgh the frame
Old 11-01-2011, 07:17 AM
Thanks I will try that.
Old 11-01-2011, 09:08 AM
turret_plug's Avatar
Bike Year, Make, Engine: No name home build
Holy shit that's funny..... I can just see you with a concerned look on your face turning your ratchet handle!!!!
I know I've been in the same predicament recently. My tail light bulb mount broke off inside the light, causing it to lose ground...... when I hit the brake switch it wouldn't work, I would lean back to look at the light and it would work..... SO I was in this strange dance of brake pedal, and lean back, LIGHT ON, brake pedal and lean forward, light off...... I was so dumb founded I actually lifted up the seat to see if there was some crazy swith in there!!!!!
Home built bobber!
Old 11-01-2011, 09:18 AM
magnum45pete's Avatar
sounds like the ratchet needs replacing........intermitant ratchet faults are a pain to find....
Old 11-01-2011, 11:10 AM
That's a hoot.
Old 11-01-2011, 01:24 PM
exactly. i was dumbfounded. i just sat there pushing that handle back and forth and turning the light on and off.
i searched for some connection from that P)(*&(*&^ light to my ratchet handle
