I'm Baaaaaaaack...
Last Post: axeychrome
Posted On: 10-23-2020
Teardrop Gas Tank Replacement
Last Post: R1_4Life
Posted On: 10-22-2020
Posted On: 10-21-2020
Old 10-29-2011, 03:08 PM
hunter_michael's Avatar
Bike Year, Make, Engine: 2010 - 107 ci Switchblade Softail Custom
OK got the parts and now am more confused. Without the step washer in I have about .02 end play, i put the step washer in and have all kinds of end play, definatley more than .02 and .06. Should I leave the step washer out and figure the inner spacer is set like this at the factory or am I supposed to have some wiggle in the axle?
This is an Ultima 60 spoke with the tapered bearings and i do have the inner spacer in.
Mike
Old 10-30-2011, 08:11 AM
Ricky-D's Avatar
Did you do that with non greased bearings?
The proper way is to take the measurements with no grease on the bearings.
Old 10-30-2011, 03:01 PM
vtwinbarblaster's Avatar
Bike Year, Make, Engine: 1975 Harley FX shovelhead
take all your new parts,put them in your truck,drive to a shop,let them do it.
Old 10-31-2011, 10:36 AM
foggdog's Avatar
Did you check it with the axle torqued down
Old 10-31-2011, 11:47 AM
Yes it was torqued.
Mike
Old 11-01-2011, 09:24 AM
foggdog's Avatar
Whats the part # on that wheel ? Me, I would have the spacer turned down the thickness of the step spacer + .010, so you can add some shims. Cause if you plan on keepin the bike, and you ever have to change bearings and races it gives you some wiggle room cause the endplay will change. And use the later yrs. endplay specs.
Old 11-01-2011, 09:51 AM
foggdog's Avatar
Unless Ultima sets the endplay with just the spacer, youd think they would specify this in the catalog. Was their a tag tied to the spokes that had an endplay spec wrote on it. But like I said, if you ever change bearings & races, that .002 could end up .020.
Old 11-02-2011, 07:20 PM
wheel part number is 36-961
Mike
Old 11-03-2011, 07:55 AM
I called Jireh Cycle and they said they have never added a step washer or shim to those wheels when putting them on bikes. They grease and put axle thru and run them. There has to be others out there running these wheels.
Mike
Old 11-03-2011, 07:41 PM
foggdog's Avatar
Hmmmm stepwasher in the back wheel though, makes ya wonder.
Old 11-03-2011, 08:25 PM
That's actually how Harley spaced the bearings out years ago, they had different length spacers, they then switched over to shortened spacer and a shim pack.
Old 11-04-2011, 05:18 PM
foggdog's Avatar
What Im sayin is, If he ever changes bearings, and races, hes got no room to shim the bearings cause of the length of the spacer. They never come out the same, (changed bearings & races in a set of H-D cast wheels, and had to remove shims in both wheels.)
So his spacer will be to long.
