I'm Baaaaaaaack...
Last Post: axeychrome
Posted On: 10-23-2020
Teardrop Gas Tank Replacement
Last Post: R1_4Life
Posted On: 10-22-2020
Posted On: 10-21-2020
Old 10-06-2011, 04:28 PM
BadHabit's Avatar
Tips For Mounting Voltage Regulator Inside Belt Drive
Anything I should know out of the ordinary as far as mounting my regulator inside my Ultima Belt Drive? Anything I should or shouldn't do?
BH
- A Society that will trade a little liberty for a little order will loose both,and deserve neither - Thomas Jefferson
Old 10-06-2011, 06:57 PM
jb1353's Avatar
Bike Year, Make, Engine: 2006 113" custom bobber, 2002 Nighttrain
As long as you have it in a place where air can flow across it you shouldnt have any problems. I usually put the regulator under the engine and mount the ignition coil on the back of the primary.
Old 10-07-2011, 02:42 PM
BH
Use some spacer so its off the plate. Even with spacers I went through 3 reg in 18 months. I put it up front, no more problems.
I'm not suggesting not to do it, its worked for many.
Old 10-07-2011, 05:11 PM
BadHabit's Avatar
Why spacers? Heat, Vibration or something else.....
Old 10-07-2011, 05:29 PM
You need air flow to keep the regulator cool.
Old 10-09-2011, 04:14 PM
hornswaggle's Avatar
Bike Year, Make, Engine: which one
what C.A. SAID
( B.T.W.I AM OFFICIALLY CHANGING MY NAME TO HIGHSENBURG )
Old 10-10-2011, 03:46 PM
Yeah, there's a reason why they mount em up front. The spacers will keep it off the plate and hopefully cooler.
Old 10-11-2011, 02:24 PM
morrison100's Avatar
Bike Year, Make, Engine: 87 fxrp ultima rigid127" WCC CFL
my coil and reg is under my tranny no problems
Old 10-30-2011, 03:38 PM
vtwinbarblaster's Avatar
Bike Year, Make, Engine: 1975 Harley FX shovelhead
my voltage regulator is also under the transmission, and i also have had no problems. (shovelhead 4 speed )
