New In Wisconsin
Last Post: CorvetteMongo
polishing tips...
Last Post: Mojorising
Open primary
Posted On: 06-20-2018
Wiring Issues, or Not?
Old 07-27-2011, 11:26 PM
Chopper-rider69's Avatar
Bike Year, Make, Engine: 2011, custom, ultima 127
Ultima 127ci and ultima 6 speed
Hey guys kinda new to the building motorcycles so i have a few questions. I just bought the new ultima 127ci motor the ultima 6 speed tranny and the 3.35 ultima drag style belt drive. can you guys tell me the pros and con's to this set up or anything i need to know! thanks
Old 07-28-2011, 05:23 AM
Need a good quality frame and rear driveline,1" (2000-up) rear wheel/axle,and especially good brakes.This big of a power planet is a whole different ball game,and requires top shelf components that will hold up.
Old 07-28-2011, 11:12 AM
Yeah the pic in my profile is the setup or what you can see im running ultima's new king spoke front and rear wheel 250 rear 21 front. now the only thing from what i hear i might have issues with is im runing a belt to the rear tire i have heard i need to switch to a chain i forgot to mention i have a nos setup im putting on this bike prolly for looks for the most part but maybe fill the tank after motor warantee runs out. the fram is a hardtail fram from Straight up choppers down in flordia
Old 07-28-2011, 11:45 AM
mgisonno's Avatar
Bike Year, Make, Engine: Santee Rigid, 120ci Ultima El Bruto
Just understand that this thing is going to rattle anything and everything loose on your bike.
I have the exact same setup of all 3 parts, except my motor is the 120ci... I go through bulbs like crazy, so replace those with LED's. All sorts of bolts, nuts, and other shit have been rattled loose, so loctite the shit out of everything and check them continously if you don't want to be stranded on the side of the road.
As well, you MUST MUST MUST break this motor in correctly to standard specs (Don't go getting it dynoed the first couple months of it's life). If you don't break this motor in correctly, you'll end up with leaky heads and a lower life on the motor. Just to set your expectations in the right realm, this motor is going to last you around 30k miles and then you'll need to do some work on it and quite possibly rebuild the thing.
All that said... there is nothing like have 125+ hp right under your nuts and gassing the throttle... makes you feel like a real man. My 120ci was dynoed to 125 hp, so yours should be a bit above that. Also, I have a higher compression on my motor... It will run with 91 octane gas, but it does sputter now and then. When I run 101 octone, it drinks that shit like koolaid and runs like a kid who just dranke a whole piture of it.
Hope this helps... let me know if you have any other questions.
Old 07-28-2011, 11:47 AM
mgisonno's Avatar
Also... I just read you're running a belt secondary drive... You need to change that immediately to chain... Just my opinion though...
Old 07-28-2011, 12:10 PM
+1 on chain
Old 07-28-2011, 01:27 PM
Hey guys thanks for the info yeah i have acess to all parts wholesale so changes arent a real big issue so i better go ahead and change over to a chain.
Old 09-12-2011, 05:12 PM
purpleride's Avatar
Send a message via Yahoo to purpleride
im running the same set up I havent had any luck with the clutch and clutch basket 3,000 miles and worn out yea i ride it hard but the metal is way to soft it should hold up better than that i would think getting ready to put a hitech on and hope i have better luck with that
Old 09-12-2011, 05:30 PM
300build's Avatar
No dis-respect intended but your kinda puttin the cart before the horse aren't ya? I mean.....ya already got the driveline so any bad stuff is moot
use a well made frame....watch the bearings in the Ultima tranny (I know guys who have had problems with em) like the other guys said...use a chain and have fun
Old 11-16-2011, 05:29 PM
evorider's Avatar
I also have this same set up and realizing that I too have to switch to a chain drive. I believe the best option for me is to "keep it simple" considering I am just a modest gear head. I did not spend the $ on a belt but I did buy a pulley brake combo, (spokster) that I will have to try and get ride of before I switch over to chain. Besides that, I have everything and ready to finish!
Old 11-21-2011, 03:37 PM
Vince81World's Avatar
Bike Year, Make, Engine: 131 C.I. S&S Custom Engine
Welcome to the motorcycle building/chopper/Pro-Street World.I hope ALL of your endeavors & undertakings pan out ,become fruitfull and provide you with many miles of smiles .
I wont comment on the experience(s) needed-nor the will ,willpower,expertise(minus the beginners luck or snags that might-or WILL Occur) or quest for knowledge that you want because you have Heart & an Interest in a field that is very *cool* and I applaud you for taking the plunge .
DONT be dissuaded (disencouraged or drawn off track) by the differing opinions here because there are MANY people here to Help,Guide , Advise and generally lend a hand to help you out.
But that same type of *HELP* here and elsewhere Is sometimes & often misguided and one sided(and much of the time well meant and Sincere)....so READ,DIGEST,LEARN,email people , ask ALOT of Questions here , and hopefully you will gain enough knowledge to assist you , guide You and direct YOU to the proper sources of information from others based on Real world Technical knowhow,USER Experience(though somehow debated as to TRUTH)-how and that equates to what YOU Need to know,digest,learn about and help you.
I wish you the BEST in all your endeavors and undertakings as far as your bike build and helpful info here to guide you thru those dire straits and scenarios.\
MANY Here will help you,Advise you and Guide You.Ask Away....just digest,read and learn from it all.
Vince
VS Customs LLC
Huntington CT 06484
Old 11-21-2011, 03:55 PM
I have the exact same setup of all 3 parts, except my motor is the 120ci... .
The 120 is the square engine so its a lot smoother, or should be then the 127" I'd take all this advice and hold on
and +10 on the chain
Old 11-21-2011, 03:56 PM
Vince
VS Customs LLC
Huntington CT 06484
vince.. very nice well wishing. nice surpize!
don't be afraid to ask question and do your home work. the net has alot to offer
do with a quility chain
Old 11-26-2011, 05:19 PM
127 Ultima
I have a 127 and have beating the hell out of it for three years without any problems. I have raised the CR to 12.1, .700 lift cam, bored and T-jetted S&S G, ported heads etc... Also using 2" Cycle Shacks w/o baffles--yes it is loud as hell when you get on it. As mentioned above be sure to use a high grade chain--forget the belt. There is absolutely nothing like this combo and is an absolute blast to ride. Good luck and DO NOT underestimate this engine!!!!
Old 10-15-2012, 05:52 PM
Bike Year, Make, Engine: 78 shovel softail chopper
Belt drive
I have a buddy who has the same set up he's thinking about running a smaller belt drive w/o the outer bearing support. I have built a few myself but never anything this big. thoughts??????????? tnx fellas
