First things first
Get the rear wheel mounted and where it needs to be with everything installed to insure correct fit, bolted tight, straight and true with the frame.
At that point you can start to see what you will need to make the transmission and the motor line up to complete the drive line.
Doing it any other way can and may work, but the downside is you may be buying a lot of parts you eventually may not need nor be able to use.
