Last Post: Southpaw1746
Last Post: Ragnar1970
Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 05-30-2020
Old 05-11-2010, 04:50 PM
"Running On"
Bike has a 96" s&s, with a s&s carb.
When shutting it off, it will shut down and give a few sputters in reverse. Also hesitates to start sometimes. When turning it over, it will seem to hit compression and struggle to get over the top. I researched and was thinking maybe timeing, had a guy check it all out, he says it's good. Bugging the hell out of me.
Any ideas.
Chris
Old 05-11-2010, 05:05 PM
have somebody else double check the timing and also check what gas "octane" you are running with that
Old 05-11-2010, 05:12 PM
Yeah shit. I have been trying different octane fuels. Seems to do it with most. It ran a bit better with mid grade. I'm not sure what it has for compression.
Old 05-11-2010, 05:43 PM
NOT PRECISE Pushrod adjustment? Collapsed lifters?
Slightly loose( or god forbid- bent) pushrods- increase cranking compression and make starter struggle
i don't believe too much advance matters- at cranking rpm the advance is near zero.
But if the ignition is in 'kick start ' mode-it tries to fire right before THE MOTOR HAS A MOMENTUM OF A FEW REVOLUTIONS AND THAT MAKES IT kick back. Make sure it's in electric start position.
Conserve the juice- turn off everything before crancking, make sure batterY is fresh, and use hEavy and short battery cables.
I got rid of the solenoid circle- by installing a push button right against the solenoid core( ~20 bucks at debrix.com)- my thumb is stronger than any solenoid to get the bendix gears engaged. A cheap fix for worn out solenoids/starters.
Old 05-11-2010, 05:56 PM
johnnyjaws's Avatar
Bike Year, Make, Engine: 08bbc.sled.79flh.83fxe.68xlch.
use high test not mid grade fuel
Old 05-11-2010, 06:22 PM
MechWerks's Avatar
High octane fuel is slower burning. That allows a higher cylinder pressure without the air fuel charge burning too soon (pre-ignition...before TDC, detonation). An S&S would most likely be high compression and require 92 or higher octane.
Running backwards when shut down suggests dieseling. Something is lighting the air/fuel without spark. Combustion chamber carbon glowing can fire idle mix. A glowing combustion chamber part (sharp edge, spark plug thread or end, etc.). Or, simple diesel from correct conditions and enough air/fuel mix (simple fix here is often a correct carb adjustment that allows the butterfly to close past an off idle port).
Starting issues may simply be a deteriorating starting system (soleniod contacts, weak battery, connections, etc.)
MechWerks
