02-27-2010, 05:44 AM
NV
Bike Year, Make, Engine: 99 Titan S&S 97", 05 Bobber S&S 113"
S&S 113 cam choice
I have an S&S 113 engine that came is in a Propper Chopper that was sold new in California. I am sure that the engine is a California certified bike with a California approved cam. I don't use the higher RPM range, at 75 the engine is only turning 2500 RPMs so I would like a cam that has low end torque, what are my options? I certainly could call S&S and get their recommendations but they are going to recommend there own cam which may be the way I go. Any suggestions, thanks..................
Bob
02-27-2010, 12:53 PM
XX
Bike Year, Make, Engine: Ratbag
Hey dair to utes,
hey's all me's club chopper folks, and friends.......... dis is a good questions, and I dun have built up a ton of dem S&S 113 engines, one dat wilts gives u's a lots of power and mid range torque would be a good ole Redshift 656 cam, Zippers uts to sell dem tings, don'ts knows bouts now duh. You's mights just give dem smart cats a call, dey do's knows what dey be talkin bouts. Wells, just checkin in heres every once in de whiles......
Man, I still can't find me smoke, anybody seen me stash?
.....It's only kinky the first time, and I'd look good on you
02-27-2010, 04:20 PM
FL
I agree with crackbaby the Zippers is a great cam but it might not just bolt in since it has .650" lift......You can call S&S with the engine serial # and if it was factory built they can tell you how much lift you can run without taking it apart to check everything. I run the Redshift in ,ost of the 113's we build in-house. The S&S .600 is a good cam as well but also might not bolt in an epa motor.
02-28-2010, 03:13 AM
ca
I got a Woods 650 lift cam in my 117. Max torque is 127 at 2600 rpm.
02-28-2010, 09:09 AM
FL
The Redshift 656 has made over 130ft lbs of torque on the 113's I have used it in and it comes on right off idle.......
02-28-2010, 10:10 AM
Ge
If you do call S&S, ask to speak with Jon Olsen, he works in their performance engineering dept, he knows his stuff and is a real good dude..!
02-28-2010, 12:13 PM
PART OF THE CREW FUCK OFF
ma
crazy to run a ....hligh lift cam and cut motor life in half....S&S 562 CAM THAT IS NOT MADE NO MORE...RAN 127 TQ mostly threw out the range, has to be plenty of 560 lift cams made making big torque.....
02-28-2010, 05:41 PM
NV
MAKO6 thanks for the heads up. I do plan on calling S&S tomorrow and I will ask for Jon Olson. I do not run hard like some of you guys and I don't want to cut my engine life in half, but always looking for a little more............
