Oil Lines
Last Post: Maustarman
Posted On: 08-14-2019
Bars upside down
Posted On: 08-12-2019
Posted On: 08-10-2019
Last Post: donald branscom
Posted On: 08-09-2019
Project Blast!
Posted On: 08-08-2019
Old 02-26-2010, 06:15 PM
87 fxr wireing problems
anyone have a digram for a 87 FXR ,not sure were to start ,I have a 3 volt drop in the wireing somewhere when I hit the start button,good battery,good starter relay ,good solanoid. Not sure about starter switch or ign switch .
any help or ideas would be helpfull.Thanks
Old 02-26-2010, 10:28 PM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
Originally Posted by bigtoolinc View Post
,I have a 3 volt drop .....when I hit the start button,
That's the classic symptom of a worn out battery
I know you said that the battery is good, but I'd bet that if you had it load tested at a shop - they'd tell you it was shot
"Hula Baby"
Old 02-27-2010, 03:26 AM
threadkiller's Avatar
VOTE FOR COWBELL!
Location: A PLACE WHERE ENGLISH IS THE SECOND LANGUAGE!, Fl
Bike Year, Make, Engine: Wrenchin & riding American V-Twins
Theres nothing "good" about H-D's choice of starter/solenoid/relay in 87. However I'd bet you're trying to push all those amps through the original cables which are now 23 years old. If your "good" means that the things you stated are "new"? thats a good thing. ANY starter's only gonna be as good as the battery and cabling behind it. Also rubber mounts are notorious for shitty grounds. Its the nature of the chassis. You might want to add a dedicated ground strap from the battery's negative post to a starter mounting bolt. Just my .02 TK.
I've been around this place for 11 years son. How about you?
Harley-Davidson..........Yesterdays technology at tomorrows prices!
Old 02-27-2010, 06:16 AM
Thats my prob , newer cable's,have a ground to the starter , and even with the starter disconected I have a 3V drop, battery checks good on a load tester and voltage at the battery doesnt drop ,and there is no voltage drop to the hot side of the solanoid either.
in numorous places I can put the ol volt meter have my 11.9-12.4V depending on how long I have been playing around with , then push the ol start button and whammO 8.8V , I was thinking ground re-did the relay ground and ck'd for draw/drops on the batt ground . Might just end up ripping it all out and starting over yet I would preffer to find and fix the issiue.Did find a wire diagram for $20 that I hope to have in a few days ,that I would be happy to post or Email if it would help anybody. yet again any input or ideas are helpfull
