Club Chopper Forums
-   -   DNA Springer question. (http://www.clubchopper.com/forums/shop-talk/81929-dna-springer-question.html)
Icon 02-02-2010 10:42 AM
I have a Springer front end and was wondering if I need to add Loctite on the nuts that hold the axle in place? Is this necessary?
Pistol GripPump 02-02-2010 02:30 PM
Absolutely!
Harley Bob 02-02-2010 02:59 PM
I drilled some dimples in the axle and then put some grub screws in the locking nuts to keep them from moving :D
zonker63 02-02-2010 03:40 PM
"grub screws" is that like set screws?
Icon 02-02-2010 03:50 PM
Should I use Blue or Red Loctite?
Pistol GripPump 02-02-2010 06:50 PM
Def use red
Razorback 02-03-2010 03:31 AM
I did not use any on mine and been riding it for two years now with no problems. Just tighten them up really tight. If I was going to loc tight it would be with blue just to make it a bit easier to take the nuts off when time to replace the tire.
Harley Bob 02-03-2010 03:33 AM
yup that's them (I keep forgetting that i'm on a US website at times :LOL:)
pop 28 02-03-2010 04:19 AM
blue only.. with red 9 times out of 10 you will need heat to remove them
rodster55 02-03-2010 07:59 AM
Used blue on mine also.
chaoscycle 02-03-2010 08:08 AM
hell no i use red and torque to harley specs, a springer wants to losen an axle nut through twisting, better to use heat to remove than lose the front wheel.
donald branscom 02-03-2010 06:49 PM
I would use blue Locktite.
If you are really worried, you can drill them and use safety wire.
Even if the nut came off the axle on a DNA springer, the axle is captured and the entire axle would have to slide all the way out to loose the front wheel.
donald branscom 02-03-2010 06:51 PM
Harley specs??? Wouldn't you want to use the specs that DNA ,the manufacturer, suggests?
rodster55 02-03-2010 07:28 PM
Agreed. If only DNA gave any specs, or instructions for that matter. I would like to order parts for my DNA springer but cannot find out how or where?
chaoscycle 02-07-2010 01:21 PM
dna gives no specs, nor would they be able to tell you with out talking to a chinese engineer, also the wheel wouldnt come loose huh , ask kendal johnson about that.
