Posted On: 05-29-2020
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Old 01-28-2010, 01:07 PM
27Cam02's Avatar
Bike Year, Make, Engine: '90 H-D Softail/PowerHouse 114 & '98FBoy
Question "Start push on" use 12 awg. or 16 awg wires??
My bike is 1990 FXSTC with 114 Powerhouse motor (high compression-ratio) and Powermaster starter. I want to change the wiring because of aged-(20 years) and worn-out.
I found out that old wire of it at "start push on" handlebar control switch-starter, looks old wire 12 awg. than I newer wire 16 awg..
Should I put 12 awg. wire? Is the 16 awg. wire ok ?
Hope, those pixes here would be HELPFUL.
Thanks for input..
Old 01-28-2010, 02:39 PM
If you are running a relay it shouldnt matter but i like to see bigger wire on the relay that actually goes to the starter it will start easier. But the other side of the relay shouldnt make much difference you are just switching the relay on .
Old 01-28-2010, 03:23 PM
Micahanjello's Avatar
I can try and explain it like this.
when you have a heavy load such as the starter circuit requires it is best to run heavier gauged wire with multistrands.
The resistance is almost eliminated getting all the power to flow where it need be. I run 12 gauge wire from my starter switch to relay and all other wires from relay are 10 gauge .
Anytime you try and funnel current from say a 16 gauge wire to a 12 gauge wire your resistance will be very high. Kinda like if you had a room that was 20x20 with 400 people in it and a fire broke out and the only exit was a 84 inch x 36 inch door.
You will definitely have a problem getting that many people out of the room amd unfortunately some will get burned.
Now if you had automatic fire sprinklers you would be okay temporarily until you made the exit larger. Meaning a fuse inline would be compared to the automatic sprinkler system it would blow until you remedied the situation by adding a heavier gauged wire.
Old 01-31-2010, 06:38 AM
27Cam02's Avatar
Handlebar (Engine Start & Stop) Switch cover/rocker has good seal waterproof. I don't think I could put 12 awg wire on it. How those guys put 12g wire on start switch? Where I can buy one ?
I use with the 30A Circuit breaker.
Old 01-31-2010, 06:45 AM
Bike Year, Make, Engine: Customs
I don't know if pushrod will remember or not but I had a thread this last summer on starter problems. It turned out to be a wire gauge problem and from there on I have gone with my wifes motto "thicker is always better". If you have a soldering iron, steady hands and some patience you should be able to figure out something on that, but yes go with the 12gauge.
Old 01-31-2010, 12:01 PM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
Originally Posted by 27Cam02 View Post
Handlebar (Engine Start & Stop) Switch cover/rocker has good seal waterproof. I don't think I could put 12 awg wire on it. How those guys put 12g wire on start switch? Where I can buy one?
That's why we have starter relays
So that you can run a small ga wire (16 ga - 18ga) through the handlebars to the relay, and then a much heavier ga. wire (10ga - 12ga) from the relay to the starter
You won't be able to buy any switches for HD OEM housings that have 12 ga wires attached
And don't waste your time trying to splice a 12 ga. onto the start button that you have now - the splice will just jam up space in the housing
If you want to use OEM style switches and housings - you need to have a starter relay
"Hula Baby"
Old 02-02-2010, 02:13 AM
27Cam02's Avatar
True...Of Course, I use the relay.
Old 02-02-2010, 02:19 AM
27Cam02's Avatar
Do you use the relay? Yes the bigger is best way to prevent big issues on starting.
I am good with soldering. I do built with LED things on cars and bikes.
Old 02-23-2010, 10:11 AM
27Cam02's Avatar
Deleted it
