Wiring Issues, or Not?
Last Post: DeafBillyGoat
Buell XB12 Chopper
Last Post: FRANKTHECRANK
Educate me on my bike
Posted On: 06-07-2018
Last Post: IHCKoy
Old 12-15-2009, 12:09 PM
lakeracer69's Avatar
Bike Year, Make, Engine: 81 custom shovel,building an 09 custom
Transmission speedo sensor wiring Question?
I'm to the point of wiring this up. Speedo is a Wire Plus round style. The sensor has 3 wires (red, black and green), I know that green is the speedo signal, and black is ground. Does the red power wire need to be connected to the ignition breaker, it seems like it would need to be for constant power when the ignition is on. The speedo has an orange wire that needs to be connected to the ignition breaker as well ( I understand that).
Maybe a stupid question, but I've never dealt with an electronic speedometer and sensor, and don't want to fry anything.
As Conan the Barbarian says, " It's not how hard you can hit, it's how hard you can get hit and remain standing".
John 3:3, 3:16, 3:36, 14:6
Old 12-15-2009, 12:22 PM
MAKO6's Avatar
Red goes to power.
Just be certain that the sensor you purchased is not for a later model year as some of them get 5VDC from the speedometer head rather than 12VDC from a primary power circuit.
Old 12-15-2009, 02:33 PM
Originally Posted by MAKO6 View Post
Red goes to power.
It's a thunderheart speedometer sensor, just the basic one. I was told that it was one of the correct ones for the Wire plus speedo.
Made sense to me to hook up the red wire to the ignition breaker.
Old 12-19-2009, 08:30 PM
hornswaggle's Avatar
Bike Year, Make, Engine: which one
if your speedo jumps around time to time clean the bottom of the sensor now and then of the metal dust that ends up sticking on it. from the tranny oil
( B.T.W.I AM OFFICIALLY CHANGING MY NAME TO HIGHSENBURG )
Old 11-26-2017, 03:19 PM
Bike Year, Make, Engine: 07 AIH Classic Chopper
i realize this is an old post...But im looking for the wiring info myself....so did this work? green to sensor, red to keyed +, black to ground?
Old 12-02-2017, 04:06 AM
yep, that's it.
