Oil Lines
Last Post: Maustarman
Posted On: 08-14-2019
Bars upside down
Posted On: 08-12-2019
Posted On: 08-10-2019
Last Post: donald branscom
Posted On: 08-09-2019
Project Blast!
Posted On: 08-08-2019
Old 10-31-2009, 07:10 PM
Lorax54's Avatar
Bike Year, Make, Engine: 1 Dirty Rigid
10,000 Mile Service
What all does it involve? Is there a checklist somewhere? Need to do one on a buddies bike. Thanks for the help.
Pray you don't look at me,
and I pray I don't look back.
Old 10-31-2009, 08:00 PM
Lorax54, be nice to know what your asking about....this is a chopper forum. Lots more care on my chopper compared to my old Honda.
Old 11-01-2009, 05:49 AM
Bodangles's Avatar
Bike Year, Make, Engine: 96" Ultima custom
There might be a checklist in a Harley manual but I've never looked.
I dont know about 10000 mile service, but this is what I do every spring
- motor oil
- tranny oil
- primary oil
- adjust clutch if needed
- check motor sprocket nut for torque
- check battery voltage and replace if neccessary.
- check tire wear and pressure.
- change fork oil (recommended every year and if you dont change it, it will look like mud)
- check all fasteners and make sure swing arm is tight.
- repack wheel bearing if necessary or do it when changing tires.
- inspect frame and front end for cracks
- lube cables with cable lube
- adjust throttle and brakes
- bleed brakes and change brake fluid if needed.
- check front and back axle torques
- Fire it up and go for a ride
- GET DRUNK IN GARAGE!!
IF IT AINT BROKEN, DONT FIX IT.......IF YOU CANT FIX IT, DONT BREAK IT!!
Old 11-01-2009, 09:04 AM
mle's Avatar
mle mle is offline
Bike Year, Make, Engine: 00 FXST 06 Roadking
What he said and adjust the primary chain if its enclosed.
Old 11-01-2009, 09:23 AM
rastoy's Avatar
Get a manual - it's all in there.
Nevermind, you're hopeless.
Old 11-01-2009, 02:22 PM
Excellent advice
Old 11-04-2009, 12:13 PM
hornswaggle's Avatar
Bike Year, Make, Engine: which one
- motor oil
- tranny oil
- primary oil
then eat some pussy to wash the beer down..
( B.T.W.I AM OFFICIALLY CHANGING MY NAME TO HIGHSENBURG )
Old 11-04-2009, 03:58 PM
winston chopper's Avatar
Bike Year, Make, Engine: 2005 CFL 127" elbruto w/ D carb, 6 speed
usually time for brakes.
Dont piss your pants to see if your fly is open
Old 11-04-2009, 04:24 PM
usually time for rear brakes/ clutch adj. tires.
