Club Chopper Forums
-   -   Final drivechain opinions (http://www.clubchopper.com/forums/shop-talk/79779-final-drivechain-opinions.html)
peter1450 10-05-2009 02:00 AM
Morning guys
Running an ISR sprocket brake setup on my CFL and have a rusty chain after a few thousand miles (yes its ridden in the rain occasionally) :eek: Must admit even though its a good quality o-ring type chain i,m suprised how quickly its corroded, although i,m a little reluctant to go mad with the chain lube in case it gets over the brake surface!
Is this something i,ll have to live with running a sprocket/brake or can anyone reccomend a chain that won,t rust without lube?
Ricky-D 10-05-2009 07:55 AM
Get used to it!
What you are looking at is surface rust and can be easily cleaned off with a rag and some wd-40 or other liquid.
I guess you'll have to get used to the rusting and occasional cleaning.
There are chrome plated chains available and I think some oxide coated chains also but eventually they will all start to have some rust appearing.
"Rust never sleeps" (Neil Young)
pushrod243 10-05-2009 10:28 AM
What about lubing it with chain wax?? The chain wax does not sling after it dries
peter1450 10-06-2009 05:24 AM
Chain wax............................never heard of it so did a search, now i know what to use, thanks John .
Xlntchoice 10-06-2009 08:30 AM
+1 on the chainwax.
http://www.mtbr.com/cat/accessories/...53_131crx.aspx
