Seen the new Harleys?
Posted On: 03-31-2020
What are these?
Last Post: erlobulldog
Posted On: 03-30-2020
Last Post: CIC2016
Posted On: 03-29-2020
Old 10-04-2009, 07:51 PM
SOCAL's Avatar
HELP! 1 inch offset for BDL pulley needed
The 1inch offset kit I bought online came with a comp. sprocket offset and I need the 1 inch offset insert for a BDL pulley. Wheres the best place to get one?
Garage Built, West Coast Style.
Old 10-04-2009, 11:07 PM
Micahanjello's Avatar
I have a 1.25 you can machine down if ya like.
Old 10-05-2009, 05:37 AM
Lorax54's Avatar
Bike Year, Make, Engine: 1 Dirty Rigid
Know that if you machine down the insert, you will be exposing splines on the main shaft. When you tighten the nut, you'll bottom out against the splines, before you tighten against the insert. It might be possible to use washers between the nut and the insert to make up for the .25" that you will be machining off.
Pray you don't look at me,
and I pray I don't look back.
Old 10-05-2009, 06:39 AM
MDsChopper's Avatar
Bike Year, Make, Engine: 2007 Custom Chopper, 1340 Evo
If you don't want to go the machining route, ebay has about the best prices I've seen. I was looking recently but I needed the whole kit. Comes with insert, nut, and hardware to attach insert to pulley. Can find the kits for about 60 shipped on average. I ended up getting it from a local bike shop as I'd rather give them my business. And they even installed it for me at no charge. :-)
Old 10-05-2009, 10:30 AM
I can prolly have one drop shipped to you if you dont find someone with one on the forum
Old 10-05-2009, 04:06 PM
does the offset come with the complete belt drive kit? if so I'm sure I have one either here in the IE or in Whittier.
