Posted On: 02-14-2020
Old 10-01-2009, 05:42 PM
bigford's Avatar
Bike Year, Make, Engine: 2006 custom rigid 110 c.i. 6 speed
Send a message via Yahoo to bigford
Exclamation 76 super glide
got a 76 super glide has been sitin for about 8 months , got it runnin, runs good ,but it smokes bad. oil smoke . i get alot of air pressure in the oil tank . if i take the oil fil cap off it stopes smoking !!!!!! put it back on in about 10 sec. it starts to smoke again . need some help guys
Old 10-01-2009, 08:42 PM
jsdiamond's Avatar
Check the ball valve in your oil pump. After sitting so long it probably settled and sumped your bottom end. Drain your crankcase, refill oil tank with fresh oil, reset ball. Or you can just reset the ball and run it out. But it will be that way (smoking) for a while.
Old 10-01-2009, 08:43 PM
caschnd1's Avatar
Something blocking your breather tube? What did you do to get it running? Did you have the nose cone off where the breather gear timing could have been messed up? You should feel a strong puff of air out the breather tube as the pistons descend on each stroke.
-Craig
Old 10-01-2009, 10:40 PM
bigford's Avatar
just new battery new plugs gas and it fired right up i did eleminate the oil lines to the primary and the chain oiler pluged them off and just filed the primary . not to up to date on shovel moters is the breather tube betwen the heads on the rocker boxes ?
Old 10-02-2009, 07:15 AM
80-80's Avatar
I'd double check oil line routing.
Old 10-02-2009, 07:25 AM
that line between the rocker boxes is the feed line from the rear cylinder cross over to the front. Make sure that your breather , oil line feed , oil line return, and oil line vent , are all routed properly, there is a thread on here somewhere that shows how they go on the or from the oil pump. Just to make sure. Good luck there bigfoot, shovels fuckin rock baby !!!!!!!!!!!!!!
Old 10-02-2009, 07:42 AM
rayfin's Avatar
Bike Year, Make, Engine: 2006 Superglide, wifes 80 KZ550 bobber
Send a message via AIM to rayfin Send a message via Yahoo to rayfin
I'd just drill a small hole in the cap.
Please watch "Loose Change 911" on youtube.
Rayfin Custom Upholstery
712-252-5878
Sioux City, Iowa
Rayfinseats@gmail.com
Facebook: Rayfin Custom Upholstery
Started doing custom upholstery in 1982. 44B Metalworker USARNG 1978. Electronics Technician.
Old 10-02-2009, 04:23 PM
johnnyjaws's Avatar
Bike Year, Make, Engine: 08bbc.sled.79flh.83fxe.68xlch.
check and see if you blocked off the breather port down by the oil pump you should have a hose comeing off the engine case that hangs down towards the ground
Old 10-02-2009, 05:00 PM
bigford's Avatar
lol got it guys i block off the breather port got it straitin around now thanks for all the help
Old 10-02-2009, 06:14 PM
caschnd1's Avatar
Sure sounded like a blocked breather. Glad you got it fixed up correctly.
Old 10-03-2009, 09:01 AM
love them shovels so easy to troubleshoot.
Old 10-03-2009, 09:03 AM
bigford's Avatar
ya i like workin on the old iron . its my friends dads bike . i got an exter frame i am looking for a shovel motor but they are geting harder and more expensive to find lol
Old 10-03-2009, 09:07 AM
Bike Year, Make, Engine: 97 1200 SPORSTER
You got that right. Use to be a million shovels around now cant find them anywhere. WTF
Old 10-03-2009, 09:56 AM
beebster's Avatar
still lots of shovels in canada!
Old 10-03-2009, 02:05 PM
caschnd1's Avatar
Lots of shovels still easily obtainable in the southwest U.S. too.
-Craig
