Last Post: chopperfugger
Oil vs fuel vs transmission line?
Posted On: 09-17-2019
return throttle cable
Tallest engine in the frame?
Posted On: 09-15-2019
Old 08-31-2009, 07:55 PM
twiceasnice's Avatar
Jackshaft problems
400km on my bike and looks like my jackshaft/pinion gear has smashed
the ring gear, took the primary off, the pinion gear is not fully engaging
the ring gear by 5mm, primary drive kit for softail 94-97 and was sent
89-93 jackshaft assembly is that my problem.
Old 08-31-2009, 08:23 PM
open or closed primary?
Old 08-31-2009, 08:33 PM
closed chain 127"Ultima 6 speed RSD 1.5KW starter
runs 5mm off with the outer cover off, bolt for jack to short to space
Old 10-04-2009, 11:12 PM
Hi John , a mate of mine (kris SA )just orderd a Primo ring gear kit from you
for me .Fitted the kit and still runs 5mm off have spaced the jack out 5mm but the
coupling just about pops out the whole thing gets hung up with the outer cover off.
running 94-97 softail primary kit (48-9884)
Late Hub & 5-SPD Clutch Hub #37550-90A
Clutch Shell for Bigtwins '94up #37707-94
all was locked and tight and lines up
(dont even need a rubber pallet for inner primary cover)
any help will be great....
Old 10-05-2009, 12:58 AM
Also noted with the bike in neutral , clutch plates removed ,primary chain connected if i spin the clutch hub the clutch shell seems to oscillate making
the chain tight then slack.
Is this my bearing shot already after 500km of riding like a pussy (running in)
as i said every thing was lined up and still tight when i pulled it down.
thank for any help
Old 10-05-2009, 08:00 AM
Ricky-D's Avatar
Storied complaint, tried and true cure.
I generally consider these problems to originate with a worn out battery.
Most dismiss this theory but eventually end up buying a new battery and when they do, all the problem disappears.
Old 10-05-2009, 04:18 PM
thanks Ricky-D
new 350cca battery and this is turning the bike over with the plugs out
and i don't see how a new battery will fix CLUTCH HUB/CLUTCH SHELL problem
Ultima 127 & 6 Speed RSD
Old 10-08-2009, 11:54 AM
an 89-93 jackshaft will not work on a 94up primary setup....I ordered the exact part #'s Kris sent. I was not part of the fitment deal.....
Old 10-08-2009, 06:01 PM
1st. I would like to say John sent the right parts ordered and thanks for the speedy delivery.
(Primo ring/pinion 84T 94-97 #1171-0001 and Jackshaft Kit 10-T 94-06 #1185-0004)
2nd. John had nothing to do with the parts used in the 1st post or any other part on this bike.
3rd. In my 1st post i said i had a 94-97 primary kit and (89-93 jackshaft as the paper work said) but this is the same as the new one so the paper work was wrong.
So iam back to were i started.
4th.What year chain drive clutch baskets should be used with a 2006 RSD SGS transmission.
This site is great and u can find most things on here but this is doing my head in.
thanks to all
Old 10-09-2009, 09:20 AM
The clutch should interchange as long as you have all matching components as far as inner, outer primaries and starter jackshaft. In other words they all need to be from the same era. 89-93 or 94 and newer.....This rule gets muddled after 2007 when HD went to their newer primary setup.
The jackshaft and its spacers should fit nicely in the primarys bushings if there is slop it will be obvious you have the wrong stuff.
Have you played with the starter and jackshaft alignment to try to eliminate that as the issue? The starter jackshaft bolt cannot be real tight or it will cause the 3 piece flexible jackshaft to bind.
The starter can get cocked as it is installed as well. The jackshaft should return freely after you pull it out to engage the ring gear. If it doesnt return loosen starter and adjust until it does.
Old 10-09-2009, 02:38 PM
hornswaggle's Avatar
Bike Year, Make, Engine: which one
Originally Posted by twiceasnice View Post
thanks Ricky-D
wow what happened to ok thx ricky il check it out. hes just telling experience with a dead bat, not bashing your prob
( B.T.W.I AM OFFICIALLY CHANGING MY NAME TO HIGHSENBURG )
Old 10-10-2009, 08:05 PM
Thanks again John , looks like i have the right part of the same era 94-97
Had another look last night and it seems the clutch hub's splines to the tranny's mainshaft to be quite sloppy could it be that the clutch hub is not fitting right on the mainshaft and thats why my jacks of
5mm .
Mainshaft splines 43mm Clutch hub splines 35.5 to the inner flat washer
thanks to all
Old 12-08-2009, 04:10 AM
thank for any help
Well here we go again ended up fitting a new clutch hub/shell and ring/pinion gear still runs 5mm off so spaced pinion gear out all good
But still have the clutch shell oscillating as above ?
Trans shaft running about 2thou out
maybe the vibration is not my 127 but my trans
any help (love the road hate the bench)
