Back again!
Last Post: Daxcobra
Weird constant alarm sound?
Last Post: ecir45
Posted On: 02-22-2018
Posted On: 02-21-2018
Old 08-12-2009, 11:17 PM
shovelhead case bore
how big could you bore a stock shovelhead case?
Old 08-13-2009, 07:48 AM
not sure i understand your question, are you talking about piston to Cylinder ? not sure what you mean boring cases.
Old 08-13-2009, 10:06 AM
Ricky-D's Avatar
As a guideline I would say to avoid boring into any bosses and especially the bolt bosses that hold the cylinders to the case.
Old 08-13-2009, 04:06 PM
BigMikeSimpson's Avatar
What cylinders you wanting to put on it?
You might check with T&O
http://www.truettandosborn.com/
Old 08-13-2009, 11:49 PM
i am lookin for a bore size. i pick up a nice setup to make a 96ci shovel. 3.825 bore i would like to go with after market cases for strength but would like stock cases for a title
Old 08-14-2009, 12:14 AM
The largest you can go on Shovelhead cases is 3 13/16.
96" is 3 5/8 bore with 4 5/8th stroke.
If you where going the biggest with that stroke crank you would get 106"
Joe
Old 08-14-2009, 03:58 AM
you want a fast shovel. check this out. email or call him he will answer your questions instead of guessing.... www.spchoppers.com he makes head and cylinder kits
Old 08-14-2009, 07:00 AM
My shovel has 3 5/8" bore and that cuts into each side of the center case bolt by about 20%............but with a 4 3/4" stroke plus 020 over cyl, its right at 100" and has held up fine for 30 yrs.
Old 08-14-2009, 07:04 AM
Bodangles's Avatar
Bike Year, Make, Engine: 96" Ultima custom
I bet that old bitch vibrates like a sum bitch!
A guy told me once not to own a shovel unless you have a good dental plan.
But you got to love em.
IF IT AINT BROKEN, DONT FIX IT.......IF YOU CANT FIX IT, DONT BREAK IT!!
Old 08-14-2009, 11:04 AM
Vibrates so bad over 75 mph I can barley hold on to it!!! And it's been balanced twice using S&S rods. It's the main reason I built my softail!
Old 08-14-2009, 03:59 PM
Originally Posted by bodangles View Post
i bet that old bitch vibrates like a sum bitch!
thats a good one,i like it ...
Old 07-25-2013, 09:04 PM
Chrism28's Avatar
What's it come out to be if its 1540? I'm new and just got my bike and the guy said its board to a 1540 it's a 77 shovel
Old 07-26-2013, 05:43 AM
Bike Year, Make, Engine: 1955 & 58 Pans
That's how I got some women in bed back in the day. If my bullshit didn't work I'd put em on the old 62 Pan and that 2 wheel vibrator would loosen em right up.
