Seen the new Harleys?
What are these?
Last Post: erlobulldog
Posted On: 03-30-2020
Last Post: CIC2016
Posted On: 03-29-2020
Old 04-14-2009, 04:09 PM
3rd gear wont work, not pawl adj
Thanks to everyone who tried to help me with my tranny with my 3rd gear issue. I tried to adjust the shifter pawl but it did nothing. At this point I am pulling my hair out and wondering why I built my bike instead of buying one, its just hard to swallow. anyone have anyone have any last ditch ideas before I scrap it. Thanks
Old 04-14-2009, 04:47 PM
Bike Year, Make, Engine: Various
What exactly is happening and what kind of trans? How many miles on it etc..
Old 04-14-2009, 05:06 PM
it is a rev tech 5 speed completely rebuilt, had 5th gear replaced due to wide tire kit so it has zero miles on it. thanks
Old 04-14-2009, 05:07 PM
I shift from 1st to 2nd with no prob then third is not even giving me a grind its like its nothing there
Old 04-14-2009, 05:28 PM
Ricky-D's Avatar
Sounds to me like your "rebuilder" needs some more schooling.
Get a manual and go thru it, any luck and you'll get it. Get it?
Old 04-14-2009, 05:45 PM
rastoy's Avatar
Got to agree with Ricky. Sounds like your rebuilder screwed up like putting the wrong gear on the wrong shaft.
Nevermind, you're hopeless.
Old 04-14-2009, 05:51 PM
MechWerks's Avatar
When you did the pawl adjustment, did it center up? Could you manually (while doing the adjustment) get into gear? May be worth pulling the shift cover and observing the shift. A fork not set in the right place, shift drum bushing pushed out or any number of assembly/shim issues can cause shift problems. Is this a static shift problem or under power/rolling? These trans don't shift until the shift dogs line up, requiring either movement of the input and/or output shaft to get the dogs aligned so things can drop into place.
MechWerks
Old 04-14-2009, 06:25 PM
Thanks for the help guys, I figured my rip off rebuilder F ed it up, its at a real custom shop now being looked at so hopefully they wont hit me to hard in the wallet.
Old 04-15-2009, 04:53 AM
occparts's Avatar
Bike Year, Make, Engine: Which one?
probably put the gear on backwards.
JB Customs
2422 W. Michigan Ave
Jackson,Michigan 49202
517-787-8730
jbcustoms.com
Motorcycles are one of life's many pleasures!
Old 04-15-2009, 08:07 AM
Lorax54's Avatar
Bike Year, Make, Engine: 1 Dirty Rigid
Let us know what the "real shop" comes back with. Would like to know where the problem was. Thanks.
