Here is what TP Engineering says about related issues, see if any of these can apply to why you are seeing excessive
oil coming from the breathers.
Trouble shooting
oil coming out top end of engine AND CRANK CASE PRESSURE
1) To much
oil in engine case, causing crank case pressure. Like a balloon building
Pressure until it escape’s.
2) Recently change oil, possibly over filled oil tank.
Take in consideration when changing oil. You will have approx ¼ cup
Of oil left in bottom of engine case.
Know what size oil tank you have before you start filling your tank with oil.
Stock soft tail is 3-1/4 qt oil. Oil filters are like sponges they will absorb approx ¼ cup of oil. Don’t over fill because the oil level looks low.
3) Oil filter blocked
4) Oil filter mounted lines crossed hooked up backwards.
5) Wrong oil filter will cause major blow by. No after markets used here. THIS IS FOR TP ENGINES
Classic oil filter part # 63796-77A EVO oil filter 40 micron
Smart oil filter can use either 5 micron, 10 micron or 40 micron
Part # 63798-99A (5) micron filters dust
Part # 63798-99 (10) micron filters small particles
Part# 63796-77A (40) micron
6) Restricting breather bolts, bolts too small. Vent holes for breathers should be (.187). Make sure when putting extension on breather bolt holes are not Covered, Defeats the purpose.
7) Oil returning in tank, vent and return are not covered in oil. This will suck oil back into engine not allowing it to breathe properly and will cause blow by, engine will get very hot.
8) Vent line inside tank, broken
9) Poor return
10) Pinched hose
11) Collapsed line
12) Race track gaskets, torn, bubbled, or worn should be replaced.
13) Piston sealing problem, low miles engine not seated yet
14) Oil cooler too high
15) Rocker box lids are backwards. Front lid on Rear and the Rear on the Front.
16) Keep in mind if having blow by issue's even after changing gaskets or oring, unless rocker boxes cavity's, carb, etc are cleaned out with break cleaner you will have left over residue that will still blow out, eventually all blow by will be gone.
