New In Wisconsin
Last Post: CorvetteMongo
polishing tips...
Last Post: Mojorising
Open primary
Posted On: 06-20-2018
Wiring Issues, or Not?
Old 09-01-2008, 10:34 AM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
Originally Posted by Ricky-D
The following comment is from the site:http://www.powerarc.com/sparkplug.htm
Initial suggested settings for spark plug gaps are:
Single plug 0.028-0.032"
Dual plug 0.025-0.030"
These are maximum settings, go down from here
Well, Power Arc is in a world of there own on this.
I don't have any personal experience with Power Arc, so I won't comment on them. But they are a Multi Spark Ignition - meaning that they fire up to three sparks at a time (as compared to one single spark in a conventional high performance ignition) under the theory that three sparks will afford a more complete burn than one
But Racers have always striven to increase their gaps (through higher voltage ignitions) in search of that "100% burn"
In the past, things like higher compression (a more dense A/F mix) have required a smaller gap to effectively propagate a flame. However modern electronic ignitions are powerful enough that they can bridge a large gap and propagate a correspondingly larger flame front
The direction that racers have always taken, has been toward having as large a gap as possible (for a given set of conditions) as opposed to as small a gap as possible
But, more impt for us:
The engine manufacturers (S&S, HD, Ultima, and just about everyone else) recommends a gap of .040
The spark plug manufacturers (Champion, NGK, and just about everyone else) recommends a gap of .040
And just about every experienced tuner (all other things being equal) will recommend a gap of about .040
Old 09-01-2008, 11:56 AM
Ricky-D's Avatar
I'm not trying to start a pissin' contest but:http://www.spyke1.com/manuals/sparkplug.htm
This is from Spyke Ignition:
WARNING:
Use only resistor core spark plug wires with all Spyke Ignitions. See spark plug wire section below.
Use resistor spark plugs with all electronic ignitions to limit the conducted EMI noise and radiated RFI noise..
Spark plug gap should be made as small as possible, while still maintaining performance. A wide spark plug gap can cause hard cold starting, misfires during rich or lean fuel conditions, and reduction of upper rpm range. To maintain a good secondary spark (multiple spark) within a wider rpm range it is wise to run a narrower spark plug gap. It is better to precisely place two stable, consistent sparks than to fire one wider spark that may cause misfires under various conditions.
Old 09-01-2008, 12:45 PM
WARNING:
Well, seeing as the wording from both the Power Arc website, and the Spyke website are IDENTICAL,
Then it's fair to assume that the same individual wrote the text for each
But they are both talking about MULTI SPARK IGNITIONS that fire multiple sparks, instead of a single spark
Totally different ballgame
So, if you apply that logic to a conventional high output single spark ignition
Then you're saying that S&S, Ultima, HD, Champion, NGK, and several generations of car, motorcycle, racer/tuners don't know what they're doing
Old 09-01-2008, 03:56 PM
Ricky-D's Avatar
Merlin, you state:
"Then you're saying that S&S, Ultima, HD, Champion, NGK, and several generations of car, motorcycle, racer/tuners don't know what they're doing"
I have made no statements.
I simply posted information from the website of the manufacturers of the ignitions.
Old 09-01-2008, 06:09 PM
King Rat's Avatar
Bike Year, Make, Engine: 2008, Rat Rod Bobber, 120
Originally Posted by bob o
anyone now what the gap should be for a Ultima 127???? I am running Champion RN9YC plugs????
I have a 120 ultima and I'm using the same plugs with a .038 gap.
Old 04-15-2009, 09:05 AM
Ok Im runnin a ultima 113 should the gap also b .040??????????? single coil ignition
Old 04-15-2009, 10:40 AM
Yes, Same gap
"Hula Baby"
Old 04-15-2009, 10:45 AM
Ok thanx Merlin much appreciated
