Grumpys King Pins
Last Post: baltimorebiker
Last Post: K001
Last Post: SYDEFEX
Last Post: chopperfugger
Posted On: 04-23-2018
Last Post: EdCase
Old 07-27-2008, 10:01 AM
RayBan's Avatar
Bike Year, Make, Engine: 04 Venom Prostreet
BDL clutch adjustment
I have the 3" BDL primary, the problem I'm havng is at slow/idle speeds. The bike tends to jerk or buck at low speeds in traffic. I don't have any problems shifting up or down or finding neutral, that all seems to work great. Is this normal for this clutch or do I need further adjustments on the pushrod? I adjusted it according to the BDL specs turn pushrod in until you feel resistence then back it out 1/4 turn.
Old 07-27-2008, 10:14 AM
MechWerks's Avatar
When you pull the clutch handle, is there a slight movment before hitting resistance?
Doesn't really sound like the clutch is having an issue unless you can feel it slipping (then something in cable or pushrod is too tight causing the clutch to slip). Are you lugging the engine at low speeds? Belt drives don't have compensators for the low speed two cylinder engine...just direct drive. Loading on the engine the wrong way will cause immediate jerking until speed increases enough for the engine to run properly.
MechWerks
Old 07-27-2008, 10:22 AM
Ricky-D's Avatar
That's what it sounds like to me also MW. Lugging at low speed even in 1st gear is always present. You have to keep feathering the clutch to avoid the problem!
Maybe there will be an automatic transmission developed soon to address the issue. With the advent of astronomical gasoline prices there certainly will be a need for such a transmission for all the newly entering motorcycle riders that are trying to avoid the expense of running their Hummers.
Old 07-27-2008, 11:19 AM
RayBan's Avatar
Kind of what I thought. Not lugging the engine at all just noticeable in rush hour traffic when moving at idle speed. Feathering the clutch is what I usually do to correct it.
Thanks for the help
Old 07-27-2008, 12:49 PM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
The compounds used on the friction plates have a big effect on the grip and it's user friendliness on the street
Stock BDL frictions are an organic/kevlar blend, that should be easy to feather
Carbon/Kevar blends, and Carbon/Ceramic blends give better bite for high HP applications, but the engagement is more abrupt
I try to feather the clutch as little as possible.
The engagement might be a little more abrupt, but the frictions and steels will last longer
Old 07-27-2008, 06:27 PM
Robocop's Avatar
I get the same problem when the bike is hot. When I'm sitting on a light the bike tends to jerk forward. A lot of people I talk to say is normal. Sometimes, it even make a clunk noise coming out of the clutch basket.
Old 07-27-2008, 08:17 PM
Krayzee's Avatar
Bike Year, Make, Engine: 06 Xtreme Cycle Design frame, TP121
are you using hydraulic or cable lines? I had the same problem using hydraulic lines. Took me awhile to find the problem, can't tell you how many times i stopped and made an adjustment on that rod setting. ended up being an adjust needed at the handle/lever. It was like is was not pushing enough fluid to fully seperate the plates. Good luck.
Old 07-28-2008, 07:56 AM
Ricky-D's Avatar
Probably, the most common culprit when having clutch (dragging related) problems in hydraulic clutch systems is air in the lines.
Even the tiniest amount of air in a hydraulic clutch system will limit travel of the slave.
The slave has such a short travel designed into it and coupled with a master cylinder designed with a small piston (intentionally so) well,,,
Just a few tiny specks of bubbles can have a immense effect on clutch operation.
Bleed that system.
Old 07-28-2008, 08:04 AM
MechWerks's Avatar
Usually parts grow with heat and that usually results in slipping. Grabbing at the stoplight is failure to disengage which is an opposite to slipping. Hydraulic systems are especially picky as air in the line is very difficult to remove and the smallest bubble of air in the system can be compressed and remove precious volume from providing adequate clutch throw.
On the other hand, the BDL drive is fairly crude and sometimes plates stick and plates smacking against dogs in the basket make noise. Getting a dry clutch wet causes rust (quickly..in minutes) and even humidity can rust highly polished metal plates making them stick to friction disc. All nature of the beast and typical to racing heritage parts. HD would have dropped their leaky and costly wet primary long ago if dry was better for street use.
MechWerks
