Buell XB12 Chopper
Last Post: FRANKTHECRANK
Wiring Issues, or Not?
Last Post: EdCase
Educate me on my bike
Posted On: 06-07-2018
Last Post: IHCKoy
Old 11-29-2007, 04:51 PM
SilverHorse's Avatar
CC 2007 Contributor
Bike Year, Make, Engine: 1973 Ironhead XLH
Originally Posted by ronbob
The ignition you need to be concerned with is part# 53-60 and 53-61. These were discontinued because people were having too many problems with them and returning them to distributors. The 53-644 is the same one I have pre-installed on my 113" and I believe Silverhorse has the same one, here is a pic
Ron
YES.. This is the one I have.. I think we talked about this too Ron..
My engine wasn't pre-run but it was preset to what Ultima specs are..
However, like Frank said you should check it anyway.. Unless of course if Frank builts your motor..
Old 11-29-2007, 04:58 PM
Originally Posted by JIREH CYCLES
the 53-644 is the pre-set ignition that comes with the motors or you can purchase them seperate, just whoever you buy it from has to contact ultima to get the right curves set.
That maybe true Now.
But that info was public. I have the settings, but right now I'm recovering from a HD crash, and I can't access my PDF's.
Old 11-29-2007, 05:12 PM
mw521's Avatar
Rest in Peace~September 6, 1952- January 15, 2009
Thats pretty bad, guess you will have to drink something else then.
Old 11-29-2007, 05:20 PM
CC 2007 Contributor
Not sure if this is what your looking for Frank but here is the Timing settings for each motor.
Old 11-29-2007, 05:22 PM
CC 2007 Contributor
Originally Posted by dmraco
Scary...you are correct..it was pre-run and time so I was told. I just had some doubt since the carb was not installed and there did not seem to have any oil leaking anyplace.
I have the similar to ronbob with the same model numbers but has some adjustments on the top. I will post a pic.
My only concern is all the piston slap I head about. TRYING TO AVOID THAT!
I am sure it's not limited to just this motor but piston slap was occuring on the 124's and 127's not the 113's..
Again not saying it couldn't happen but those were the troubled engines.
I think however Ultima fixed the problem??
Old 11-29-2007, 05:31 PM
Have you seen some of the threads on here as to how people have timed these things?
There's no doubt in my mind that most of the troubles were owner error!!!
And, No Robby, The info I was talking about was the dipswitch settings....I believe they are the same as the Dyna.
Old 11-29-2007, 05:38 PM
CC 2007 Contributor
Yeah I agree Frank.. Most were as us computer guys call them.. ID10T errors.. Or just some didn't check..
I personally didn't check mine but my dad did check it for me.. I guess if you can't trust your own dad who can you trust..
Is the dipswitch settings in the Manual Frank? I will post them for you if they are?
Old 11-29-2007, 05:41 PM
ronbob's Avatar
Bike Year, Make, Engine: 2007, Garage Built, 113" Ultima El Bruto
yes I paid like $50 extra for the pre-run service from Jireh
Old 11-29-2007, 05:43 PM
It was in one of their ignition manuals. Not the engine manual. It may still be online. No disrespect to anyone, but right now I have much bigger fish to fry. Sorry.
Old 11-29-2007, 05:45 PM
CC 2007 Contributor
If it's the same as the Dyna 2000 you can try this site.
http://www.dynaonline.com/english/instruct/D2K-HD1.pdf
Old 11-29-2007, 05:46 PM
I can't view the pdf right now. I'm tryin to recover other files!!!!!!!
Old 11-29-2007, 05:50 PM
CC 2007 Contributor
Quit yelling!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I feel your pain brother.. I deal with this stuff everyday.. Much easier to fix at work, no so easy at home.
Old 11-29-2007, 05:52 PM
dmraco's Avatar
Bike Year, Make, Engine: Old School Bobber & 2 UP CFL
thanks Scary and Jason...
Jason...Glad to see you are sticking around...nice to see your help even though I purchased from somome else.
2007 Custom Bobber 100 inch RevTech
2 up CFL: 113 inch El Bruto
Old 11-29-2007, 06:01 PM
ronbob's Avatar
Jason what exactly is included in the pre-run service through Jireh?
Old 11-29-2007, 06:06 PM
dmraco's Avatar
I think Randy from Southern told me the ignition was made by Dyna. I will check the settings on my dipswitches. I think they were all in the down position except for #3.
