Turn signals
Last Post: gduncan
Posted On: 07-09-2020
Posted On: 07-08-2020
Identify Frame *Help
Last Post: gduncan
Posted On: 07-06-2020
Old 03-31-2007, 02:44 PM
Stynie's Avatar
Oil seal leak..CAN'T FIX!!!
I don't know what else to do. After changing this f in thing 3 times,the crank seal on my bike is still leaking!!! I have changed the spacer, siliconed outside of the seal, installed it "squarely", siliconed the stator bolts. Please spare me the "Harley's are supposed to leak". This one isn't. It's an Ultima 113. I don't know what else to do. I have read other threads on this subject, and tried what others have suggested, but..............
Old 03-31-2007, 02:52 PM
Can you tell exactly where the leak is coming from?
Between the spacer and the rubber?
Old 03-31-2007, 02:53 PM
lorider93's Avatar
Bike Year, Make, Engine: 01 road king flhri
if you are running an open primary i beleive yo uare suppose to install the thing backwards, but not sure pm mr. scary he is more familiar with that problem. how many miles on your motor?
Old 03-31-2007, 02:57 PM
Toecutter's Avatar
Bike Year, Make, Engine: Rigid 88" flatside Shovelhead
Are you sure the seal is going in the right way? Open end facing in. If all else fails you might have a crankcase breather issue.
Pete
Old 03-31-2007, 03:04 PM
lorider93's Avatar
check all the oil lines make sure nothing is clogged it can happen
Old 03-31-2007, 03:31 PM
BOSS's Avatar
i have the same problem....another 'wrench' told me it could be the amount of offset (i have a 1.5") causing it...he thinks an outer bearing support may correct the problem. i have replaced mine a few times and it always leaks...i put on some extra 'gasket goo' as well...oh well as i say...'it adds to the mystique'....
Old 03-31-2007, 03:44 PM
canius-lupis's Avatar
Has any one tried a speedy sleeve on them to tighten the tolerance.
Old 03-31-2007, 03:54 PM
You guys are missing something.
If it's leaking between the rubber and the sprocket shaft spacer(pic below),
Then one of the two is bad. If you need an outer bearing support, then you had better check your main bearing. because the sprocket shaft should not be moving around even with an open primary.
Old 03-31-2007, 06:53 PM
Stynie's Avatar
no it's hard to tell. i had it out today for the first time since changing the spacer and new seal. when i stopped and got off, i looked down and it was dry. then it came out about 30-40 seconds later. lol.....looked like when you cut yourself and it dosen't bleed right away....then. so when i got home i tore it apart and it was kinda wet all over. i wiped just the seal to see if anymore would weep between the seal and the case, but no more appeared. it's a 1" offset, but i myself don't think that has anything to do with my problem, but what do i know, i can't stop this leak. i am using $4 seals. should i try something better?
Old 03-31-2007, 07:11 PM
rastoy's Avatar
Try putting an o-ring on the shaft before you put the seal on. I did that when I reversed my seal on my 120 Ultima and so far (knock on wood) so good.
Nevermind, you're hopeless.
Old 03-31-2007, 07:42 PM
Stynie's Avatar
you mean behind the spacer?
Old 03-31-2007, 09:17 PM
Yes, behind the spacer. If you don't, then the oil will drip in between the spacer and output shaft. Maybe that's where your leak is?
Old 03-31-2007, 09:19 PM
Stynie's Avatar
you know, i was thinking that. i guess you don't want one too thick right?
Old 03-31-2007, 10:08 PM
PORKROASTER's Avatar
Bike Year, Make, Engine: basket case
It NEVER leaks when standing still? If this is the case, I doubt the seal is the problem.
MM looking Eastward into which Valley to travel next.
Old 04-01-2007, 05:39 AM
BiggyD's Avatar
breather issue
It's a chopper baby!!
