Last Post: Southpaw1746
Last Post: Ragnar1970
Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 06-02-2020
Posted On: 05-30-2020
  #121 (permalink)
Old 04-04-2007, 08:40 PM
Originally Posted by Stynie
Na man, I know what you mean. I was saying, inside the rotor it actually rides against the spacer which spins inside the seal. So I think there shouldn't be excessive stress no matter how tight the nut.........again...think, not sure though.
I'm not sure either.
  #122 (permalink)
Old 04-04-2007, 09:26 PM
Bike Year, Make, Engine: 2000 road king, 2001 buell
couple other thoughts, ive not read all the posts so sorry if its been said, clean the area very very well then try talcom powder to find first sign of leak, also theres uv dyes avail for autos that have hard = impossible to find leaks
  #123 (permalink)
Old 04-05-2007, 11:49 AM
For your engine(because you don't have shims), Your rotor buts right up against the sprocket spacer(not the washer spacers, but the spacer that goes in before the seal).
Your pulley insert buts up against the rotor.
The nut goes on.
None of that ever touches the seal.
  #124 (permalink)
Old 04-05-2007, 12:03 PM
Bike Year, Make, Engine: 2003 Custom Build, 1994 Wideglide
Exactly right MrScary...if it did, the seal would be torn to shit as soon as you fired the motor up.
FTW
I.O.F.F.I.O./MBBM
  #125 (permalink)
Old 04-05-2007, 01:37 PM
The nut goes on.
I was wondering how that worked. Thanks Frank.
  #126 (permalink)
Old 04-09-2007, 03:22 PM
BOSS's Avatar
i still fucking leak !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! FUCK !!!!!!!!!!!!!
  #127 (permalink)
Old 04-09-2007, 05:30 PM
BOSS's Avatar
i am starting to wonder if the shaft is bent....
  #128 (permalink)
Old 04-09-2007, 05:35 PM
Stynie's Avatar
Man that sucks!! Haven't had the chance to ride mine yet. I used an o-ring behind the spacer, new seal(obviously),and vented the lower case. In your case, I would think you'd be able to see if the shaft was bent by looking at the front pulley.
  #129 (permalink)
Old 04-09-2007, 05:38 PM
BOSS's Avatar
yeah...but a slight bend maybe not...but just enough to fuck the seal up...
i took it our today and it didnt leak at first...started after a while.
what size was the o-ring you used?
tomorrow the seal goes in the way they come from the factory....spring out...with blue form a gasket....rather then the copper i have been using.....anyone thing i could wedge 2 seals in there? just a thought...how much room is in there?
there is NO way i am fucking putting these seals in wrong every god damn time.
  #130 (permalink)
Old 04-09-2007, 05:45 PM
Stynie's Avatar
I,believe it or not, went to Lowe's with the spacer in hand to the plumbing section and bought some cheap assortment. I used a thin one that had to stretch to get over the shaft. I also put "Right Stuff" all over the o-ring. But like I said I haven't tested it yet, so.....
  #131 (permalink)
Old 04-09-2007, 05:46 PM
Stynie's Avatar
Hey, did you beat on it or just cruise around? Just wondering about pressure issues.
  #132 (permalink)
Old 04-09-2007, 05:48 PM
BOSS's Avatar
hmm...maybe i should coat everything with Permatex Grey gasket maker...
http://www.permatex.com/products/aut...sket_Maker.htm
Permatex® Ultra Grey® Rigid High-Torque RTV Silicone Gasket Maker
OEM specified. Designed specially for high-torque and high vibration applications, like those common in import engines, this premium RTV gasket maker exceeds manufacturers' performance requirements. Noncorrosive and low-odor. Maximum vibration resistance, with outstanding resistance to oils, cooling and shop fluids. Guaranteed not to leak. Temperature range -65ºF to 500ºF (-54°C to 260°C) intermittent.
Suggested Applications: Valve covers, oil pans, intake manifold end seals, timing covers, water pumps, thermostat housings
  #133 (permalink)
Old 04-09-2007, 05:49 PM
BOSS's Avatar
i cruised for a bit...it was pretty cold..once it warmed up..i hammered on the bitch.
  #134 (permalink)
Old 04-09-2007, 05:50 PM
Stynie's Avatar
This is the shit I used(also great on Ritz crackers): http://www.permatex.com/products/aut...sket_Maker.htm
  #135 (permalink)
Old 04-09-2007, 05:53 PM
Stynie's Avatar
I asked cause I've been thinking. One of the times I changed the seal, I took it out for an easy ride and it didn't leak until the next when I had done a few holeshots. So maybe it is a pressure issue as some have mentioned.....maybe.
