Turn signals
Last Post: gduncan
Posted On: 07-09-2020
Posted On: 07-08-2020
Identify Frame *Help
Last Post: gduncan
Posted On: 07-06-2020
  #106 (permalink)
Old 04-02-2007, 07:10 PM
Sorry I couldn't be more help.
  #107 (permalink)
Old 04-02-2007, 07:16 PM
Stynie's Avatar
No don't be sorry, I appreciate everyone's help.....very much so.
  #108 (permalink)
Old 04-02-2007, 07:38 PM
Ace of Spades's Avatar
Member/Admin
I'd try the crankcase vent if the oring doesn't hold.
This is on a S&S but should be the same for the Ultima. Note the green line...
Red-Feed line from tank to pump.
Yellow-Pump to oil filter input, inside port closest to crankcase.
Purple-Return line from filter to oil tank. From center of oil filter.
Blue-Vent to oil tank.
Green-Open crankcase vent
  #109 (permalink)
Old 04-02-2007, 07:49 PM
The only problem I have with uncorking the crankcase plugs is that the Ultima engines come with the newer style nose cone. (93-99)
that can lead to abnormal oil spewing from the crankcase vent hose.
I know S&S recommends running both vents.
Ultima does not.
  #110 (permalink)
Old 04-03-2007, 05:54 AM
BOSS's Avatar
morning..thats the same stator/rotor that i run...its thick eliminating a spacer..but i still run one...i replaced seal last night...spring in...went in way better...the sleeve appeared Ok...had a slight nick in it but not in an area that i thought would matter...i put gasket shit everwhere.....on the sleeve where it meets the seal, inside and outside lips of the seal, in the sleeve where it goes over the shaft...EVERYWHERE.....put that fucker in and put another coat of gasket shit on....gasket shit on the spacer where it meets the sleeve and then put the rotor on......put it all back together.....i fired it up and not a drop until a few hours later (but this could have been oil i didnt get cleaned out).....no more this morning then the one drip from last ngiht....gonna rain here for a few days so i wont be able to get it out now for a while to test it. : (
  #111 (permalink)
Old 04-03-2007, 12:15 PM
Stynie's Avatar
I thought you said you had it spring in before, but mechanic told you spring out.......no? Anyway, keep us posted.
  #112 (permalink)
Old 04-03-2007, 12:46 PM
BOSS's Avatar
well...i always did put it spring in and the mechanic did say spring out...but you must remember .....these are HD dealer mechanics that have ZERO open primary experience...so i went by everything i read and by people like MrScary and Gypsy who say spring in..i just figured maybe i am doing something wrong and will give it another shot.....it only takes me 10min to change these things anyways!! a small leak does not bother me...i would rather have no leak...but when i changed it on the weekend i had a gusher!!
  #113 (permalink)
Old 04-03-2007, 06:36 PM
Stynie's Avatar
I was thinking that too, that's why I asked.
  #114 (permalink)
Old 04-03-2007, 10:50 PM
Bike Year, Make, Engine: 2000 road king, 2001 buell
a thought, long time ago i had a set of cases the main bearing insert where its casted into the case actually was tiny tiny bit loose, with heat it became more apparent, also putting a pipe on the sprocket shaft with nothing to block view ie pulley off ect the play was there to see, again just a thought
  #115 (permalink)
Old 04-04-2007, 05:30 PM
Stynie's Avatar
I thinking of trying the vent hose. I picked up an o-ring, a vent(little baby air cleaner lookin thing) and the extended fitting for the crankcase as well a new seal. If I point the hose straight up, will there still be a spewing issue? Also I spoke to local mechanic today about my problem. He said to try the vent. He also mentioned the possibilty of what EnglishJoe said.......Man I hope that ain't the case.
  #116 (permalink)
Old 04-04-2007, 05:34 PM
Not sure. Give it a shot and let us know.
It's a relatively cheap experiment.
  #117 (permalink)
Old 04-04-2007, 07:52 PM
Just a thought, is it possible that the front pulley nut is being overtightened on the crank causing too much pressure against the seal? Does everybody use a torque wrench to tighten the nut? I've seen lots of guys use impact wrenches.
  #118 (permalink)
Old 04-04-2007, 08:23 PM
Stynie's Avatar
I may be wrong, but the front pulley essentially is being pressed against the spacer which is inside the seal.........no? BTW, I do use a torque wrench each and everytime.
  #119 (permalink)
Old 04-04-2007, 08:28 PM
I dont have a spacer on mine. My pulley fits against the rotor, which is up against the seal. I wasn't directing my comments at you, BTW, I was just thinking in general. Lots of people have had this problem, and I'm wondering what the common cause, if any, could be.
  #120 (permalink)
Old 04-04-2007, 08:35 PM
Stynie's Avatar
Na man, I know what you mean. I was saying, inside the rotor it actually rides against the spacer which spins inside the seal. So I think there shouldn't be excessive stress no matter how tight the nut.........again...think, not sure though.
