Last Post: juanba
Rear wheel spacer
Posted On: 05-25-2020
Pushrod adjust.
Alternator/rotor
Last Post: Daxcobra
  #91 (permalink)
Old 04-02-2007, 05:09 PM
Stynie's Avatar
WHOA!!!! Who's thread is this???? Just kidding First, my mistake, I do have shims in for the front pulley. Second, my seal looks exactly the same as the pics Scary posted. Third, I took the vent hose off and it's clear. Blew air in it towards tank to be sure. Also blew air gently into vent hose fitting and heard right away as clear as day through the air cleaner. So I'm thinking it's not a pressure issue.
  #92 (permalink)
Old 04-02-2007, 05:14 PM
But, is your oil returning to the tank properly?
It's a reach, but I'm really at a loss with this.
  #93 (permalink)
Old 04-02-2007, 05:18 PM
Stynie's Avatar
[quote=Mr Scary]But, is your oil returning to the tank properly?=QUOTE]
How do I check? Maybe try a better seal? maybe??...
  #94 (permalink)
Old 04-02-2007, 05:21 PM
Stynie's Avatar
Maybe I'll try sprayin everything down w/brake parts cleaner, button it up, run around the hood, then yank it apart to try to tell where it's coming from..........again. I want to try the o-ring thing, but I really don't feel like changing the seal to do it.
  #95 (permalink)
Old 04-02-2007, 05:22 PM
Again, this is a reach, but what type of fittings are you using?
Particularly on the return side...from pump to filter to cooler and back to tank.
  #96 (permalink)
Old 04-02-2007, 05:26 PM
Stynie's Avatar
Same size that came on the motor, 1/4,5/16 or whatever the actual size is. I'm not running a cooler.
  #97 (permalink)
Old 04-02-2007, 05:27 PM
1/8 and 1/4.
Like i said, it was a reach. LOL
  #98 (permalink)
Old 04-02-2007, 05:33 PM
Stynie's Avatar
So you think I should give the o-ring a try. It does seem like a reach, but if there's a small nick on the crank, then maybe..........
  #99 (permalink)
Old 04-02-2007, 05:35 PM
Like I've said before, I've never tried it.
If it works, let me know!!!!!!!!!!!!!!!!!
  #100 (permalink)
Old 04-02-2007, 05:41 PM
Stynie's Avatar
Do you know the diameter of where the o-ring would sit?
  #101 (permalink)
Old 04-02-2007, 05:52 PM
I'm not really sure where they were talking about. If you need the od of the sprocket shaft, I can check.
  #102 (permalink)
Old 04-02-2007, 07:02 PM
Originally Posted by Rhode Warrior
Nah, well be OK.
The trailer was for my benifit, not yours.
  #103 (permalink)
Stynie's Avatar
I think it needs to sit behind the spacer ,where it will CRUSHED!! But I'm ready to anything at this point.
  #104 (permalink)
Old 04-02-2007, 07:04 PM
LOL!!
you were watchin 24 weren't you. LOL LOL
  #105 (permalink)
Old 04-02-2007, 07:07 PM
Stynie's Avatar
Was actually channel surfin', or like my wife says"Watchin EVERYTHING". BTW, I can get that diameter from mine, it's still apart.......Thanks
