Last Post: chopperfugger
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
  #61 (permalink)
Old 04-02-2007, 01:43 PM
Originally Posted by Rhode Warrior
My pulleys are lined up without spacers. In fact, I had to have my front pulley machined down on my Primo Brute IV because it was too far out (too far away from engine).
That's a little different because you had it machined to your specs.
  #62 (permalink)
Old 04-02-2007, 01:50 PM
So the spacers don't come with the charging system, you just buy them if you need them?
  #63 (permalink)
Old 04-02-2007, 01:54 PM
Steve, I still don't really understand the offset issue you had.
I'm not familiar with the DNA setup. But I don't know why anything had to be machined.
But, as long as everything is lining up, it's all good I guess.
  #64 (permalink)
Old 04-02-2007, 01:58 PM
Do you have a picture of an Ultima crank showing the stator installed? Does the seal stick out past the stator? I'll see if I have a picture to show you what I mean. Could it be that the rotor on my charging system is thicker than others? I'm curious about that myself. All I know is I had to have 1/2" machined off of my front pulley.
  #65 (permalink)
Old 04-02-2007, 02:01 PM
BTW, not trying to hijack your thread Stynie, it's all related.
  #66 (permalink)
Old 04-02-2007, 02:03 PM
No. The best pic I have is the one below.
I'm wondering if you should have had your pulley offset 1/4"-1/2 smaller and used the spacers in the pic I posted.
  #67 (permalink)
Old 04-02-2007, 02:06 PM
Im starting to wonder the same thing. Although, that would have taken too much off of the pulley spline.
  #68 (permalink)
Old 04-02-2007, 02:07 PM
I have to head out for about 20 minutes. When I get back, I'll post a picture.
  #69 (permalink)
Old 04-02-2007, 02:51 PM
Here you go (127 Ultima): Note ghetto engine stand.
  #70 (permalink)
Old 04-02-2007, 02:54 PM
That's plenty of spline for a smaller offset insert.
  #71 (permalink)
Old 04-02-2007, 02:57 PM
It was cheaper to cut mine down.
  #72 (permalink)
Frank, does this look like your stator and rotor setup? Is yours that thick?
  #73 (permalink)
Old 04-02-2007, 02:58 PM
Your rotor looks different then mine in that mine was flat across the entire back side. Yours appears to have a spacer kinda built in.
  #74 (permalink)
Old 04-02-2007, 03:00 PM
That's what I thought. The rotor on my Revtech 100 was flat too.
  #75 (permalink)
Old 04-02-2007, 03:03 PM
Ok, I'm going on a pic here, but it does appear that the rotors I have used were thinner.
Hang on. I have to have a rotor somewhere.
