Worth Chopping?
Ultima 113
Last Post: Southpaw1746
Posted On: 06-03-2020
Last Post: Ragnar1970
revtech to baker trans swap
Last Post: bjh
Posted On: 06-02-2020
Old 04-02-2007, 12:20 PM
BOSS's Avatar
then what is skylarbluepuppy talking about ?? he says spring out...which i always thought was wrong. when you say you have run them both ways...do you mean on an open primary ? should i try it spring out ??
Old 04-02-2007, 12:23 PM
Yes, I have ran them both ways on an open primary. Basically because I had no desire to get a new seal and swap em. No leaks.
When I have to either start from scratch or replace a seal, I put the spring in on open primarys.
Again, the spring should face the pressure.
Old 04-02-2007, 12:30 PM
BOSS's Avatar
k....i'll give it another shot....this is the same whether its a HD seal or aftermarket
Old 04-02-2007, 12:31 PM
Boss, have you checked your sprocket shaft spacer good for nicks?
Old 04-02-2007, 12:32 PM
BOSS's Avatar
i'll check it tonight.....
do you mean the sleeve that fits in the seal or the spacers that came with the charging system?
Old 04-02-2007, 01:01 PM
Stynie's Avatar
He means the sleeve the seal goes around. My charging system didn't come with spacers. Should I have them,and could that be my problem????
Old 04-02-2007, 01:03 PM
Old 04-02-2007, 01:06 PM
BOSS's Avatar
thats what i figured you meant
Old 04-02-2007, 01:09 PM
Obviously, the seal seals the surface of that spacer, so if there's any gouges or nicks, oil will get through.
Alot of people overlook that.
Old 04-02-2007, 01:28 PM
This is kind of off but I thought I'd post it.
I use A/N fittings on all my pluming whenever possible. It's just something I prefer to do from back in the v-8 days.
Anyway, I made a set of lines the other night.
I usually use Earls fittings and Russell hose.
I wasn't able to get everything from earls, so I used A few Aeroquip fittings.
What I noticed, was that even though the both brands were #6 A/N, The Aeroquip brand had a smaller ID. On both the hose ends and the a/n to npt adapters. Earls ID was bigger.
The reason I'm posting this is because I'm concerned with the restriction the Aeroquip will cause.
Obviously, the smaller ID will restrict oil flow.
Now, If oil is getting backed up, at any point from the return side of the pump, through the filter to the cooler, back to the tank, would this contribute to exessive pressure in the case? Possibly causing leaks.
How are your lines set up? Could this be an issue for you guys?
Are your fittings restrictive at all?
Old 04-02-2007, 01:29 PM
Stynie's Avatar
Mr Scary, did you see my previous post about charging system spacers? Needed or not,and could that my problem?
Old 04-02-2007, 01:35 PM
BOSS's Avatar
you need them if your pulleys arent aligned....is everything lined up good ?
Old 04-02-2007, 01:39 PM
No. I don't think that's your problem. The spacers aren't designed to be sealers. And The leak is most likely before the missing spacer anyway.
Although I will say that I'm a bit confused as to how your front pulley is in alignment with your clutch basket without any spacers.
Old 04-02-2007, 01:42 PM
BOSS's Avatar
yup...me too
My pulleys are lined up without spacers. In fact, I had to have my front pulley machined down on my Primo Brute IV because it was too far out (too far away from engine).
