Last Post: Southpaw1746
Last Post: Ragnar1970
Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 06-02-2020
Posted On: 05-30-2020
Old 04-02-2007, 09:30 AM
BOSS's Avatar
replacing my seal again today....mine went in way crooked the other day somehow (never done it that bad before)...its leaking just sitting there!!!
will also inspect the race.
Old 04-02-2007, 10:39 AM
BOSS's Avatar
So i just went to the stealer to pick up a couple seals and explained my leak to the parts guy who talked to a mechanic there....they said the seal should be pointing spring in on a open primary since that is the way the seal works....i thought that went against the way everyone has been doing it. (FYI. I am runnning a 3" BDL open)..so i am going to try it the way they said spring in and add some gasket shit (since the HD ones dont ahve any on it)....your thoughts??
Old 04-02-2007, 10:44 AM
Stynie's Avatar
I have been installing it with the spring in.
Old 04-02-2007, 10:51 AM
BOSS's Avatar
sorry i meant to say ....the HD mechanic said SPRING OUT.....which is the opposite of what i have been doing
Old 04-02-2007, 10:57 AM
skylarbluepuppy's Avatar
Bike Year, Make, Engine: 06 pitbull
spring out with open primary i believe. its just the opposite of factory
Old 04-02-2007, 10:59 AM
BOSS's Avatar
now i am getting confused....my Ultima came spring out....everyone said flip it..i did and it leaked.....so i am gonna do spring out tonight
Old 04-02-2007, 11:02 AM
Stynie's Avatar
Originally Posted by BOSS
.my Ultima came spring out...so i am gonna do spring out tonight
Mine too. Let us know what happens going the other way.
Old 04-02-2007, 11:03 AM
BOSS's Avatar
so your came spring out.....and you changed yours as well and leaked?
Old 04-02-2007, 11:07 AM
RRSA's Avatar
Bike Year, Make, Engine: CUSTOM MOPED
Mine came spring out, leaked right off the bat. Changed to spring in, thus far no leaks.
Old 04-02-2007, 11:08 AM
BOSS's Avatar
Fuck This Is Driving Me Crazy !!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-02-2007, 11:21 AM
Stynie's Avatar
They all come with the spring out, because they are set up for a wet primary. I really don't understand why that mechanic said to spring out for an open primary.
Mine came from the factory with the spring in.
Old 04-02-2007, 11:24 AM
BOSS's Avatar
what engine ? HD ??
BOSS's Avatar
me either...but he tried to explain thats how the diaphram works or something...you like to belive they know what they are talking about.
Old 04-02-2007, 12:17 PM
Boss, Rhode Warrior had the same engine as you.
The theory is that the spring should face the pressure.
Meaning in your case, the spring in towards the engine.
They come set up for a wet primary. so from the factory, it's spring out.
I guess they figure it's more important to keep the primary fluid out of the engine.
I've run them both ways without problems.
